TB Bypass help
Old Feb 15, 2002 | 12:09 AM
yellavette94's Avatar
yellavette94
Default TB Bypass help
Can someone post a link to the page that tells how to do this. Pics would be helpful. I know this can be done with parts from my local hardware store but which parts do I need? Please help if you can. What kind of SOTP and actual HP gain can I expect?
Old Feb 15, 2002 | 12:13 AM
87-2NV's Avatar
87-2NV
Default Re: TB Bypass help (yellavette94)
Jim, Go under "search" type in "TB Bypass" under archived and you'll find detailed info on this.
[Modified by 87-2NV, 11:14 PM 2/14/2002]
Old Feb 15, 2002 | 12:45 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
Go to tech tips section or do a search...you'll find plenty of instructions... :cheers:
[Modified by Yello95, 11:45 PM 2/14/2002]
Old Feb 15, 2002 | 01:46 AM
yellavette94
Thanks guys!
Old Feb 15, 2002 | 03:18 AM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
If you get a 95 hose you can get rid of the t-fitting on the upper radiator hose.
Old Feb 23, 2002 | 06:34 PM
yellavette94
Default Re: TB Bypass help (BrianCunningham)
I will lose some coolant when I do this. Do I have to replace with Dexcool?
Old Feb 23, 2002 | 06:42 PM
RadPolo96's Avatar
RadPolo96
I tried to do the TB bypass a little while ago but I had a problem with the hose. When I tried to pull the original hose off the TB it seemed to be fused on. I would have just jerked it hard to get it off but I didnt want to rip it. Any ideas?
Old Feb 23, 2002 | 07:19 PM
okinawa86vette's Avatar
okinawa86vette
Default Re: TB Bypass help (RadPolo96)
Sometimes they get stuck on there pretty good over time. The only way to get it off is to cut it or jerk it. You might want to have some spare tubing on hand just in case, or have another car you can take to a parts store.
As for losing the coolant, if your car has dexcool in it, its only compatible with dexcool and should be topped off with that. I believe it is pre mixed, so you shouldn't add water.
Chris
Old Feb 23, 2002 | 08:14 PM
STL94LT1's Avatar
STL94LT1
Try twisting the hose off with a pair of plyers. This may damage the hose, but it probably needs to be replaced anyway.
Old Feb 23, 2002 | 08:15 PM
STL94LT1's Avatar
STL94LT1
My 94 did not come with dexcool.
Old Feb 23, 2002 | 08:19 PM
mn_vette's Avatar
mn_vette
try heating it up, if you've ever had to change a hose on a hot engine you'll notice they come on and off really easy
Old Feb 24, 2002 | 12:27 AM
yellavette94
So how do I know if I have Dexcool or not?
Old Feb 24, 2002 | 02:29 AM
merrick's Avatar
merrick
Dexcool is orange I believe. You will only loose a cup or two of fluid
Old Feb 24, 2002 | 03:13 PM
Scooby's Avatar
Scooby
Just cut it off with a blade. You have plenty of spare when you route the driver side over to the pax side 'pipe'.
To TB Bypass help
