correct idle?
Old Jul 28, 2009 | 04:29 PM
MP6's Avatar
MP6
Default correct idle?
What is the correct idle for a 92 lt1 sixpeed?
thanks
Old Jul 28, 2009 | 05:01 PM
aklim's Avatar
aklim
Why do you care? Have you done any mods or chips? Is there an issue you are trying to solve? Most importantly, do you have some sort of scanner? My Auto-X-Ray will tell me exactly what the commanded idle speed is. What yours is in the chip we don't know. Also why are you wanting to know? Do you suspect it is too high or just running erratically?
Old Jul 28, 2009 | 05:50 PM
STL94LT1's Avatar
STL94LT1
750 rpms on a warm engine.
Old Jul 28, 2009 | 06:16 PM
-=Tom=-'s Avatar
-=Tom=-
Old Jul 28, 2009 | 06:39 PM
RLG's Avatar
RLG
Keep one thing in mind that the factory Tachometer has a tendency to become a little inaccurate after a while, mine is about 250 RPM off. It has something to do with an electronic component. I have a digital inductive dwell/tachometer that verified this.
the tach shows 1000 RPM's but is actually running at 750.
So don't rely on your factory Tach.
Old Jul 28, 2009 | 08:22 PM
MP6's Avatar
MP6
Thanks!
Old Jul 29, 2009 | 09:50 AM
joe3906's Avatar
joe3906
If you can't rely on a tach, what is the best way to know what your idle speed is? I installed a cam in mine and the idle was erractic, but after cleaning the IAC, it has become a lot steadier.
Old Jul 29, 2009 | 10:43 AM
Steve20's Avatar
Steve20
RLG is entirely correct
95 6 spd my tach shows 2500 rpm but it is actually 2237 as noted by state inspection paper readout
Steve
Old Jul 29, 2009 | 11:43 AM
aklim's Avatar
aklim
At that point, all bets are off. You need to have the chip reprogrammed for that cam and they will set the idle there. My command idle is 800-900
Old Jul 29, 2009 | 12:10 PM
SunCr's Avatar
SunCr
Specs are +/- 50 rpms from Targeted in Drive (Auto); +/- 100 rpms in Park/Neutral (Auto/Stick). You need to scan it to find out if it's right.
Old Jul 29, 2009 | 02:05 PM
aklim's Avatar
aklim
Actually, ASSUMING the chip is programmed right and the timing is set right and no other issues are present, I set the IAC by the counts. I get it warm and in closed loop first. Hook up scanner and see what the IAC counts are. Adjust throttle position screw till I get 15-20 counts. Set TPS (some can and some cannot be set. I hogged mine out so it can be set), clear codes and go on my merry way.
To correct idle?
