D-36 or D-44
Old Jul 28, 2009 | 06:28 PM
C4vettrn's Avatar
C4vettrn
Default D-36 or D-44
I am going to be switching gears and was wondering how much tourqe/Hp. can the D-36 handle? next question is how hard is it to convert? do I need the entire batwing? does it bolt rite in or are there other problems?
My long term goals is a 400-450 hp. engine, would the posi unit hold up? is there even a diffrence in the posi units between the two?
How strong is the 700R? can it be left alone with the hp I am looking at?
My only experience was setting up a Mopar 9 1/4 with a sure grip posi. I would imagine all clutch type units are close to the same other than the size of the clutch packs?
Old Jul 28, 2009 | 06:32 PM
jhammons01's Avatar
jhammons01
Everyone on the forum will tell you to go with a D44
'cept me
Old Jul 28, 2009 | 06:39 PM
92ZR1WANNABE's Avatar
92ZR1WANNABE
If your going for 400-450 at the crank through a auto , I would say the D36 will probably hold just fine. You will only be getting about 328-369 to the tires at those levels.
I have heard that D36's will hold roughly 400 hp so it should be good as long as you don't get to wild on drag radials or slicks
As for a 700R4 , dunno if a stock unit will hold that power.
Personally I will probably run my D36 until I break it, then I will swap it would.
Old Jul 28, 2009 | 07:41 PM
rssshen vette's Avatar
rssshen vette
I'm running a 383 in my 85. I'm getting about 390rwhp and 420rwtq. The 700r4 in stock form will not hold up to that HP and TQ. I've learned this first hand. I'm having my tranny rebuilt to handle the torque. As for the dana 36....I've been running 3:73 as long as I've had my 383 and since then I've only had to replace the spider gears. A lesson I've learned always use the water box. Never do a dry burnout with BFG Drag radials 315/35/17). To keep from shattering my rear gears I usually launch at 1500rpm. All done on BFG Drag radials 315/35/17.
You can't go wrong if you upgrade to a dana44 .... I plan to someday
Old Jul 28, 2009 | 08:18 PM
rodj's Avatar
rodj
http://forums.corvetteforum.com/c4-t...er-limits.html
Old Jul 28, 2009 | 08:30 PM
pologreen1's Avatar
pologreen1
44 is best, but if you can't plant the power to the ground with sticky compound or track situations, I would not woory too much. I think if you have the car set up good enough to plant the power, than you got problesms, but most people can easily get HP, the problem is transfering it to the ground.
Old Jul 28, 2009 | 09:56 PM
aboatguy's Avatar
aboatguy
IMO if you are planning on installing gears to your d36 it would be the time to buy a D44 (assuming you would be happy with 3.45 gearing)
Lately I've seen some D44s going for reasonable prices
JMHO
However, if you're spinning you aint winning (and probably are safe with a D36)
Mike
Old Jul 28, 2009 | 11:09 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
We installed a 3.70 in a Dana 36 with a 383 stroker, motor about 10 years ago. One pass at the track and the side of the carrier blew out. We removed the carrier installed another new one with the same gear and had the same results. 1 new gear one blown up rear! The caps were pulling out from the torque and blowing the side out! (I may still have some pics of this, but it was ugly).
We then converted to the Dana 44 and had great luck but they are not indestructible. The 44 blew up too and we never new if this possibly was from the half shaft twisting off or if the rear end gave out again. I would personally use the 44 but you'll still have to be careful.
You’ll need the rear wing, the rear and the trans member to change to the 44.
If I remember correctly and it’s been a very long time, there is someone making a cast iron version of this rear end on the west coast, it’s been to long.
You’ll need to change the sprag in the transmission to a hardened one if you don’t you’ll tear this out too! As mentioned above the tranny will not hold up unless you beef it up!
On major difference in the 36 and 44 is the bat wing which on the 44 has two thrust pads built in to it. These pads will help keep pressure on the main caps.
Good luck, I’m sure there may be others that will post more info.
IMHO,
Willcox
Old Jul 28, 2009 | 11:13 PM
rodj's Avatar
rodj
Aftermarket D36 gearsets are almost twice the price of D44 ones
Old Aug 7, 2009 | 09:18 AM
gerardvg's Avatar
gerardvg
i am running an 85 vette with auto a toughened t700r4 and d36 308 rear supercharged and intercooled 8 psi boost its been that way for the past 3 years and do 11.9 quoarter mile and has run without a problem. however a manual trans will be harder on a diff and that is why manuals came with the d44
Old Aug 7, 2009 | 09:23 AM
RacerX70CC's Avatar
RacerX70CC
D44 for any serious HP... 700R4 can be made to live behind HP, but at a cost.
I run a D44/TH400, but that's just me (1.48 60ft times)
Best of luck to you
Old Aug 7, 2009 | 10:55 AM
rodj's Avatar
rodj
But what are your 60ft times and do you have sticky tires ; DR's or similar?
A D36 will survive with soft launches.
Old Aug 7, 2009 | 12:54 PM
pologreen1's Avatar
pologreen1
'cept me
unless you can get the power to the ground, I have 2.59's in my vert, until I put in my 3.75's and it burns the tires on stock motor. I don't plan on having much traction with 3.75's and over 400 chp.
If you go to the track, and use DR's then I would think at like 450 of so you might be done soon.
If I could do it over I would have saved my money on gears, and install kit, and bought a d44 with 4.11's in it already. for a little over 1k, almost the same as buying gears, and having them installed. and I got my gears cheap compared to most.
To D-36 or D-44
