I replaced my ignition coil but forgot to seperate the cable connectors that go to the front housing. One connector end is white the other is brown. I have a Hayes maint book but it does not show where they go.
The cap has 3 connections on drivers side.
White connector-pink wire> firewall side of cap connections
Brown connector-white wire> plenum/drivers side of cap connections
Black connector-3 wires from dizzy base> plenum/pass side of cap connections
I believe it's impossible to fit them into the wrong connection, so it's all good.
