Autocross Upgrades
Old Jul 28, 2009 | 10:28 PM
rokgod7's Avatar
rokgod7
4th Gear
Default Autocross Upgrades
I have a 96 Collectors Edition and Autocross in the Ohio Valley Region SCCA. I run in the BSP class because I have already added thicker Antiroll Bars from VB&P front and rear, an SLP cold air intake, and I am also using Nitto NT01 comp DOT tires. I recently aligned the vehicle as well, dialing in -1.5 camber up front, and -1 camber in rear. I have ordered a lowering kit, but not installed yet. My question is that I would like to maybe upgrade suspension bits and maybe other performance mods and wondering if there are any other C4 autocrossers out there that can share their experiences on things that I should do, or things I shouldn't waste my money on.
Old Jul 29, 2009 | 09:01 AM
TravisD's Avatar
TravisD
You might want to move over to the Autocross and Roadracing sub-forum...
Old Jul 29, 2009 | 10:26 AM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
One of the best things you can do is buy the rear end kit form Banski Motorsports Tom's (forum member astock165) product is top notch and better built than any other kit Ive seen. This heim jointed kit really stiffens up the rear suspension and make the car handle better than you thought!
Old Jul 29, 2009 | 10:43 AM
TravisD's Avatar
TravisD
I just checked the SCCA BSP ruleset, and it isn't clear to me where a heim-jointed suspension is legal...
Old Jul 29, 2009 | 10:45 AM
Kubs's Avatar
Kubs
Your right. My bad. Heim joints put you in SSM. Sorry..
Old Jul 29, 2009 | 11:31 AM
Bad Karma's Avatar
Bad Karma
I've done a little. The ride from the upgrade to poly bushings makes a good difference. Biggest suggestion I have is to print the rulebook and make sure what class you want to stay in.
The autocross forum has more info, and guys who do it all the time.
Old Jul 29, 2009 | 11:52 AM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
There's a lot of mods you can do in Street Prepared
It all depends on how far you want to go.
The 335's I run on all 4 corners are legal in SP
You can't touch the longblock, but any intake or engine management system are legal
You can run Penske shocks as well
A full cage stiffens it up.
Take a look at this National car
I'm about to install those, it puts you into SSM, where my supercharged stroker motor is legal.
Top National cars have 600+hp to the ground.
Old Jul 29, 2009 | 11:55 AM
StealthLT4's Avatar
StealthLT4
Poly bushings will help. Also, if you aren't using 17x11 lightweight wheels on all 4 corners, that would be a big benefit as well. I'd recommend Kumho V710's, as they keep their grip a lot longer than the Hoosier A6. That, and as Bad Karma said, know the rulebook inside and out. Oh, and seat time. No substitute for that.
Old Jul 29, 2009 | 06:30 PM
jwt1603's Avatar
jwt1603
Seat time makes the most difference assuming you're new to this.
And as mentioned above check the autocross road race section and learn the rule book inside and out.
Old Jul 30, 2009 | 09:51 AM
BrianCunningham
Dedicated BSP cars run offset bushings to get more camber in the front.
Though that might be alot more than what you want to run on the street.
They also run springs that would kill your kidneys.
Old Jul 30, 2009 | 09:31 PM
rokgod7's Avatar
rokgod7
4th Gear
I'm using a set of stock C6 wheels I got for free from my dad. I don't think 335's would work without rubbing unless I do a wheel upgrade too. Is this your car? It's pretty freaking awesome, my compliments. What kind of springs and shocks do you use? I'm thinking that should be my next purchase. Maybe rear camber rods and such as well. Your thoughts? I'd like to keep this a streetable car, but that being said, I don't mind a harsh ride. I'm contemplating QA1 adjustable shocks, and a hyperco front spring. But VB&P has a front spring available as well. Since I am new to this, if I spend what little money I have, I want to make sure it helps. I think one of my biggest problems is front dive under braking. I'm hoping the lowering kit will help with that, but I suspect I still either need more spring, shock, or both.
Old Jul 31, 2009 | 01:39 AM
USAsOnlyWay's Avatar
USAsOnlyWay
People seem to perfer the Koni's over the QA1s for autox, for drag racing it flips and QA1s are perferred. Of course there are Gary's ("Hardbar") Penskes which would be great. I went cheaper (and they don't have Koni yellows for early C4s) and got the VBP Xtreme (Moracco valving) Bilsteins and I have been pretty pleased with them. They make the ride pretty stiff though regardless of the springs. Check the AutoX forum for people who do it as more than a casual thing.
Old Jul 31, 2009 | 07:21 AM
worldsaway's Avatar
worldsaway
I do alot of autox in either a CSP miata or BSP C4, and it's amazing how competitive these cars can be. You are thinking in the right direction, get more grip, since you probably have more power than you can keep hooked up. There is less drama with either A6's or V710's, allowing you to stay focused on the line. I'm running C5 magnesium wheels (think LIGHT) with 295 fr/315 r, and have more understeer than I like. I wish I had 315's all around like brian. I just bought the vb&p front spring, but haven't installed it yet. Ed
Old Jul 31, 2009 | 07:24 AM
worldsaway's Avatar
worldsaway
Ooops, caught my typo, I wish I had 335's
Old Jul 31, 2009 | 07:50 AM
Strick's Avatar
Strick
Small note: Keep an eye on your rear wheel bearings as mine had to be replaced after 2 years of auto X. Beware, it's also an addicting sport that cost as much as crack or whatever dope is out there. I quit when SCCA put cars in BSP that I could not compete with. Too political.
Old Jul 31, 2009 | 09:39 AM
mrc24x's Avatar
mrc24x
Hi Rokgod,
What part of Ohio? I'll be at the NASA event at Mid Ohio August 14-16th racing/instructing. You should come check it out or better yet, enter! The cheap way is to sign up for "Hyperdrive". It costs $59 and you get 30 minutes on track in your car w/ an instructor (as fast as you want/feel comfortable to go) and a 30 minute classroom session. Since you are already an Autocrosser you may want to sign up for a full day Friday, or Sat and Sun. or all 3 in HPDE1 for the first time even w/ your experience.
Let me know if you're interested and I'll hook you up w/ a free 1 yr. NASA membership ($45). Link:
http://www.nasagreatlakes.com/
FWIW I run VBP Extreme springs, 32/26 sways, revalved Bilsteins, poly bushings w/ all stock control arms. My Data Aq. shows me consistantly hitting 1.8-1.9 g's. (A few over 2 g's before she really breaks loose )
Cheers,
Matt Carlyle
NASA #26 PTA/TTA
Old Jul 31, 2009 | 09:40 AM
BrianCunningham
Originally Posted by Strick
...I quit when SCCA put cars in BSP that I could not compete with. Too political.
It's a shame what the SCCA did to the class.
All that would up is that a lot of people are staying home!
Here's a thread on it, LONG THREAD, lot's of BS too
http://sccaforums.com/forums/1/371816/ShowThread.aspx
The bottom line though is just to have FUN.
I've show up to autox's on my worn out all-season tires.
I wasn't the fastest, but I didn't care.
It's nice to get the car out there and have some legal fun with it.
To Autocross Upgrades
Old Jul 31, 2009 | 10:25 AM
jwt1603's Avatar
jwt1603
If you want light weight wheels go with CCW's.
I used to run the Maracca valved Bilsteins but switched to QA1 double adjustables this year. Took care of the nose dive you mention. And the ride isn't nearly as harsh. (It's an autocross / track only car so no street driving for comparison but some pit areas are pretty rough and the QA1s don't seem to break my kidneys as much).
Try talking to Paul at Van Steel for a spring / shock set up. You need to have pieces that compliment each other. He seems to know what he's doing and doesn't just sell you stuff to make comission on it.
http://www.vansteel.com/
Most of all have fun!
Old Jul 31, 2009 | 01:32 PM
worldsaway's Avatar
worldsaway
My C4 is still competitive in BSP at the local level, atleast if my co-driver is driving.
Old Aug 9, 2009 | 08:03 PM
c4danc's Avatar
c4danc
2nd Gear
Help me out please. I have been autocrossing my 95 stock for the past year. i finally have money to fix it up. What modifications do i need to put 17X 11s on all 4 corners? what is the backspacing required? do you think you could post a link for rims? Also what suspension mods should i do to my car?
