Vacuum Hose Question
Old Jul 31, 2009 | 08:33 AM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Default Vacuum Hose Question
I just removed my cruise control vacuum diaphram, that sits right above the battery, in order to mount my accusump. I now have two hoses with no place to go. One is a smaller diameter and goes to a T fitting which is the line that gets the vacuum from the engine. I am just going to cap the T and remove this hose. The second is a bit larger diameter and goes through the firewall. Where does this one go? Can I just leave it open ended, or should I get a fitting to connect the two lines?
Old Jul 31, 2009 | 08:56 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
You can leave it open.
Old Jul 31, 2009 | 10:21 AM
M. Schumacher's Avatar
M. Schumacher
It goes to the switch on the brake pedal.
Old Jul 31, 2009 | 12:48 PM
Kubs's Avatar
Kubs
So when I hit the brakes it releases the vacuum holding the throttle open? This means I can plug it without it affecting anything.
To Vacuum Hose Question
