Crankshaft Pulley
Old Jul 31, 2009 | 12:03 PM
Whitecloud's Avatar
Whitecloud
Default Crankshaft Pulley
I have my serpentine belt off and all the pulleys spin fine except the crankshaft pulley. Is this correct or should the crankshaft pulley spin too?
Old Jul 31, 2009 | 12:20 PM
Muffin's Avatar
Muffin
If I understand your question correctly; No the crankshaft pulley is bolted to the crankshaft. Only turns when the engine is running. The crank pulley drives all the other pulleys.
Old Jul 31, 2009 | 01:12 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
That pulley drives the entire pulley system, so no, it shouldn't turn. If it does you are in big trouble.
Old Jul 31, 2009 | 02:08 PM
Whitecloud's Avatar
Whitecloud
Thanks, just wanted to make sure.
To Crankshaft Pulley
