88 no start possible pass key?
Old Jul 31, 2009 | 01:29 PM
Y-ME's Avatar
Y-ME
Default 88 no start possible pass key?
Got an 88 the occasionaly won't start, turn the key and nothing no click at all. still have all electrical power, wait 20 minutes or so and she starts right up. I tried putting one of thos bypasses on the harness under the steering column and still nothing.
what's this cars malfunction?
Old Jul 31, 2009 | 02:46 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
May be the starter. You need to see if you're getting power to the starter when you turn the key.
Old Jul 31, 2009 | 03:07 PM
engle1147's Avatar
engle1147
Could be park/ neutral safety switch, starter relay or ignition switch.
Old Jul 31, 2009 | 06:34 PM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
sounds like VATS to me.
Old Aug 1, 2009 | 06:29 AM
WVZR-1's Avatar
WVZR-1
Dan,
What did you try for a "by-pass thing"? There's so many issues and VATS is generally the first thing that everyone "assumes"! Do you have mutiple keys? Do you have a DVM/mutimeter? If you've got a meter, check the resistance of the key and then check the value at the connector near the bottom of the column. If that's a match you can likely rule out the key cylinder and the key if the key resistance was within the required range.
Now for an early MY you're down to the VATS module and I've never had a VATS problem with an early MY with a VATS module.
Is the car at your home? I could maybe put my hands on a VATS interogator and stop by on the way home! Check everything else, cables, connections, starter, maybe replace the starter enable relay and get in touch!
Old Aug 1, 2009 | 09:43 AM
kmhene's Avatar
kmhene
Default Wont start:
Had the exact same problem with my 84 about 3 weeks ago. Sometimes I would get nothing also. But had full power for everything else. I have no VATS for the 84 and replaced starter. And that was it.
They sit close to the exhaust so I dont think they last long with that constant heat from the exhaust. You can put a heat shield on the side of it I think. I did not, but wished I did now.
I am sure its your starter.
Kevin
To 88 no start possible pass key?
