Broken valve spring!
Old Aug 1, 2009 | 11:19 PM
rodj's Avatar
rodj
Default Broken valve spring!
More of my ongoing problems
Does this look a pre existing fault?
Either side of same break shown. Half of spring face is smooth , the other is obviously broken.The break on the other end of spring is rough across both faces.
2nd pic shows what appears to be a shiny wear spot where spring was working on itself before breaking.
Lunati #73943 running at .555 ; spring rated to .630.
Any comments?
Old Aug 1, 2009 | 11:36 PM
pologreen1's Avatar
pologreen1
OUCH! everything else ok?
Old Aug 2, 2009 | 01:35 AM
rodj's Avatar
rodj
The keepers jammed in the retainer holding everything up.Didn't notice at first when I pulled the covers because rocker appeared to be working fine and the spring was compressing.Just wasn't coming back up onto the seat .Was running open headers so didn't noticing the chuffing from that cylinder
Old Aug 2, 2009 | 02:12 AM
pr0zac's Avatar
pr0zac
i just bought some patriot gold extreme's.. $275 shipped. sounds like you might want to look into them. you can get the gold's for $250.
Old Aug 2, 2009 | 01:07 PM
STL94LT1's Avatar
STL94LT1
Even though the springs are good to .630 lift their installed height could have been wrong causing coil bind.
Old Aug 2, 2009 | 03:15 PM
JAKE's Avatar
JAKE
Since one broke, look at the others for witness marks for the cause. If the spring(s) went into coil bind you should see shiny areas, perhaps on the unbroken springs where two coils touch and rub against each other.
If no sign of contact I'd suspect the spring material. Bad batch?
Moroso, and probably others, sell a seat pressure tester that you can use to see if the other springs have become weak from either being over-worked or from a bad batch. If seat pressure has dropped by more than 10% I'd change all of them.
Jake
West Point ROCKS!
Old Aug 3, 2009 | 09:16 AM
rodj's Avatar
rodj
No ,there is no sign of any touching on the broken or the other springs.
Compressed there is a visible ( yet to measure ) gap between all the coils.
Have bought Neat's TFS 195 LE ported heads that have Pac beehive springs so shouldn't have any future problems
To Broken valve spring!
