code 42 help
Old Aug 2, 2009 | 07:14 PM
hill's Avatar
hill
Default code 42 help
1990 non ZR1 keeps giving me a code 42 have replaced the ECM and the Ignition Control Module. Checked the wires to the Module from the ECM the best i can tell everything seems to be ok. Can any one help me
Old Aug 4, 2009 | 09:49 AM
hill's Avatar
hill
come on now someone knows whats up with it
Old Aug 4, 2009 | 01:23 PM
DVNCI's Avatar
DVNCI
I had this on a 93 and it was the coil
Old Aug 4, 2009 | 02:13 PM
SunCr's Avatar
SunCr
42 for this Year means it's not switching over to the Module which is simply grounded by the ECM to control timing. There is a barrel disconnect on a tan wire that's close to the battery which you open to set base timing. Yours may have been left open, may have been opened during an emissions test to check base timing and the code wasn't cleared, or the connector may be broken.
Old Aug 4, 2009 | 04:26 PM
hill's Avatar
hill
I will but a coil on it and see whats happens I know a 93 has a different set up
but what the heck worth a try
Old Aug 4, 2009 | 04:29 PM
hill's Avatar
hill
I have cleared the code every time and have checked that fitting I will check again just to be shurr
Old Aug 6, 2009 | 05:50 PM
hill's Avatar
hill
Replaced the coil and rechecked the fitting. Same thing still getting code 42
Old Aug 6, 2009 | 09:11 PM
kycharlie's Avatar
kycharlie
NCM Member '09
Don't know if this will help but try this webb site:
http://www.asashop.org/autoinc/may97/techtips.htm
DM
Old Aug 8, 2009 | 09:15 AM
hill's Avatar
hill
OK now i am getting code 42 and 43 WTF
Old Aug 8, 2009 | 10:11 AM
kycharlie's Avatar
kycharlie
NCM Member '09
I was still getting an intermittent code 42 and 43 like you. I'd replaced the ECM, plugs, fuel filter, ect. and finally disconnected the negative battery terminal and disconnected every plug from the ECM forward. I made sure every connection was clean and tight. I also checked every ground connection. After I reconnected the battery, everything seems to run normal. Once in a while I get a momentary change in exhaust sound and the fuel mileage indicator on the dash shows some weird readings like 99 MPG and the service engine light will flicker, but as suddendly as it appeared, it goes away and the engine runs great. It won't set a code now, only that occassional flicker of the SES light. I'm going to connect a fuel pressure gauge to it next and tape it to the windshield so I can watch it while I drive. Guess we'll see where that leads us.
DM
Old Aug 8, 2009 | 10:53 PM
hill's Avatar
hill
DM
I am going to check all the grounds next and go from there
Old Aug 9, 2009 | 09:49 PM
SunCr's Avatar
SunCr
Then you need to check the wire from the Module to the ECM to make sure it's not open. Otherwise, the White wire from the ECM to the Module is essentially your timing control. Grounded by the Module, it's essentially and on/off thing. Make sure that wire is good - in fact, make sure the Module connector is secure.
Old Aug 10, 2009 | 10:11 AM
hill's Avatar
hill
I checked the white wire and the brown wire they both seemed to be good so I replaced them just to be sure. . I also replaced the knock sensor and plug in for it. That is after a few nuts and a welding burn cause the knock sensor broke in the motor. Same thing
Old Aug 15, 2009 | 08:07 AM
kycharlie's Avatar
kycharlie
NCM Member '09
Default Problem Solved
I finally took mine to a well know shop and they determined that the ECM had failed. This was the third ECM in 2,000 miles. The problem was a "Super Chip" installed in the ECM. They removed it and the car's running great. What was your outcome?
kycharlie
Old Aug 15, 2009 | 10:54 AM
hill's Avatar
hill
kycharlie
well after i replaced the knock sen and the plug in i pulled the the distributor and replaced the pickup. SO FAR SO GOOD!!!! Dont know why but that seemed to fix it. Glad you got yours fixed
To code 42 help
