Yes I know this is probably a beginner question...
Yeah I know this is probably a rookie question but... I am changing my brake master cylinder and need to know how to bench bleed it before I reinstall the new one.. Thanks in advance for not giving me too much flack...
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Thats a good article, but has anyone actually seen a bench bleeding kit at an autoparts store?
Anyone know a manuf or exact part number?
I'm going to need to replace at least 2 master cylinders this year, and maybe a third so having the "kit" would be a good thing to have (I have 3 older vehicles, 2 corvettes and a mustang if it matters)
i have to install mine
what is this whole bench bleed thing ?
what if i bleed the system in the normal way ?
Bench bleeding refers to removing the air from the master cylinder prior to installing it on the car. This is nessisary because on the car the master cylinder is not level. You could level it once installed by jacking up the rear until the MC is level and then "bench bleed" it if you don't have access to a vise.
The "normal way" is to bench bleed a master cylinder off the vehicle.
It is not impossible to bleed the MC by bleeding the cailipers but it isn't easy and will consume more brake fluid. I've seen several posts here over time where in people didn't bleed the MC off the vehicle and pulled their hair out trying to get a good pedal.
In this video the guy is able to bleed the master on vehicle because it is level. Notice the drip at the line! If you push the MC's rod too fast with those plastic nipples on they can pop right off. Slow will work fine tho.
You can bleed it on the car just as easy only it takes 2 people just bleed it before you reconnect to the lines get some real fittings that you use in place of the plastic fittings in the MC and bleed the system then attach the lines and check for pressure.
onluy it's dangerous to your paint to bench bleed on the car incase of entrained air bubbles bursting out of the orifices and getting brake fluid on the paint.
I listened to folks ONE time with the Bench bleed BS.
Wound up being a complete waste of 30 minutes.
Are we to suggest the the brake pedal does not get every bubble out? I ranted about brake bleeding before. And the reason being that it only takes me 15-20 minutes to bleed the system with one of my teenage boys or my wife pushing the pedal when I say push.....
Yet despite this success spanning almost 30 years, I continue to see these threads full of all kinds of ways to bleed the system.
"Push".....your helper pushes the pedal
You open the valve and let a little fluid out and close it quickly
Your helper holds that pedal until you say "release"
Repeat
You'll see clear fluid and bubbles come out when you are done
Move to the next wheel, repeat.
There is a special sequence for ABS brakes, and I don't know it off the top of my head.
I never touch those bench bleed hoses and fittin's.....
lemme ask you something, this is nice video, but what happens when he pulls that red fitting off???
Wouldn't air get in the lines at that point?
So I'd like to know, if air is in the lines at the point where they connect to the master cylinder, what did the guy gain? He still has to move a bubble from that point to the release valve at the wheel cylinder and out the valve.
So He removed any bubbles from the MC plunger......what is that?? 1/4" gain in where the bubbles are located within the system?
