Damnit...help!!
Old Aug 3, 2009 | 05:51 PM
Pwnage1337's Avatar
Pwnage1337
Default Damnit...help!!
Alright I just finished wrapping up the corvette.
I took it apart and
-ported intake manifold base
-installed as&m runners
-installed ported plenum
-relocated IAT (plenum had a blockoff plate where IAT is)
-eliminated CSI
Now when i try to start it, it cranks and backfires through the exhaust..i heard that when it backfires through the exhaust that the timing is too far retarded, so i advanced the timing a bit and it backfired through the intake. it was REALLY loud, not like it did when i first got it where they were minor backfires.
Is the timing really that sensitive? When i move it the slightest bit it backfires through the intake, if i move it back it backfires through the exhaust.
SAVE ME!@!!!
Old Aug 3, 2009 | 05:58 PM
farscape1a's Avatar
farscape1a
it's also possible the spark plug wire is on the wrong plug... i actually made that mistake on another car...
Old Aug 3, 2009 | 06:39 PM
Pwnage1337's Avatar
Pwnage1337
I numbered the spark plug wires when I took them off, but I suppose I could have misplaced some.
Any other ideas?
Old Aug 3, 2009 | 06:53 PM
Joe C's Avatar
Joe C
did you adjust the valves?
Old Aug 3, 2009 | 06:58 PM
farscape1a's Avatar
farscape1a
Any other ideas?
i guess just check and re-check your timing. i'm an LT-1 guy and don't have to check timing and such, so i'm not real good in that respect... sorry...
Old Aug 3, 2009 | 07:20 PM
cv67's Avatar
cv67
St. Jude Donor '05
Double check to make sure the dist. is in right and the firing order is correct.
Old Aug 3, 2009 | 07:27 PM
floridamale's Avatar
floridamale
Sounds like timing could be off. Bring #1 cylinder to TDC compression stroke check rotor position should be pointed @ #1 cylinder and check mark on harmonic balance should be 6* on tab. If necessary pull and reposition dizzy. Firing order 1-8-4-3-6-5-7-2 looking from front of motor clockwise on dizzy, moving the dizzy itself counter clockwise advances timing
Old Aug 3, 2009 | 07:48 PM
Pwnage1337's Avatar
Pwnage1337
Thanks guys, ill work on it tomorrow and keep you guys posted.
You have to adjust the valves???
Old Aug 3, 2009 | 07:54 PM
Pwnage1337's Avatar
Pwnage1337
Old Aug 3, 2009 | 08:02 PM
Pwnage1337's Avatar
Pwnage1337
Old Aug 3, 2009 | 08:18 PM
floridamale
Unless you did something to them they should not have to be adjusted, dosen't sound like you messed with the heads so they should be OK
Old Aug 3, 2009 | 08:57 PM
larry00's Avatar
larry00
Yep sounds like the Dist. wasn't put back right do the #1 thing and listen to it roar !
Old Aug 3, 2009 | 09:49 PM
John A. Marker's Avatar
John A. Marker
with floridamale. Distributor and wire issue.
Old Aug 4, 2009 | 02:34 AM
Pwnage1337's Avatar
Pwnage1337
Thanks guys!!
To Damnit...help!!
