Stereo Trouble Codes
Old Feb 15, 2002 | 08:16 PM
Too Slow '90's Avatar
Too Slow '90
Default Stereo Trouble Codes
I recently posted about changing the stereo in my '90. Looks like it took a crap so I'm going with a new unit. Someone said there was an archived post about trouble codes when you change out the head unit. I have not been able to find the post. Anyone know where it is? Thanks. :chevy
Old Feb 15, 2002 | 09:53 PM
Dualnic's Avatar
Dualnic
Default Re: Stereo Trouble Codes (Too Slow '90)
Most people get SYS after changing out there factory radio to a aftermarket radio......the reason is that a resistor need to be in place with the dimming circuit of the radio......i am pretty sure u can get more info on this subject in the "Audio/Electronics" Section.
Old Feb 16, 2002 | 06:35 AM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Do you have electronic or manual A/C
That's where the problem is. If you have manual you need to add a resistor to the system.
Old Feb 16, 2002 | 02:18 PM
Too Slow '90
Default Re: Stereo Trouble Codes (Jeffvette)
It's electronic. Does that mean I don't have to do anything? :confused:
Old Feb 16, 2002 | 03:24 PM
Jeffvette's Avatar
Jeffvette
Correct, just throw it in and be done with it.
Old Feb 16, 2002 | 08:48 PM
Too Slow '90
Kewl! Thanks. :chevy
Old Feb 17, 2002 | 12:26 AM
Da-Cajun's Avatar
Da-Cajun
Sorry but that's not correct. If you have the automatic temp. control, you will get the sys. when you pull the factory radio and add an aftermarket system. There is the need to put the resistor inline.
Old Feb 17, 2002 | 08:18 AM
Too Slow '90
Default Re: Stereo Trouble Codes (Da-Cajun)
:crazy:
Old Feb 17, 2002 | 04:43 PM
Jeffvette's Avatar
Jeffvette
Gee, kind of strange, mine didn't need the resistor.
Old Feb 20, 2002 | 02:25 PM
RED90VETTE's Avatar
RED90VETTE
Default Re: Stereo Trouble Codes (Dualnic)
I also changed to an aftermarket radio,and where I had it done said that it was not necessary to use that resistor,Six months and no problems.
To Stereo Trouble Codes
