Code 45 1988 TPI Engine skips while cruising
Old Aug 3, 2009 | 10:05 PM
1988_chris's Avatar
1988_chris
Navigator
Default Code 45 1988 TPI Engine skips while cruising
Hi,
I'm new here. Hope someone can help. Have 1988 Corvette, getting code 45. Motor skips and loses power while driving at a constant speed. Have replaced the following with new parts; Not sure what to do next.
Plugs
Cap and Rotor
Fuel Filter
EGR Valve
PCV Valve
O2 Sensor
Plug Wires
Chris
Old Aug 3, 2009 | 10:29 PM
CalvinMD's Avatar
CalvinMD
What does a code 45 mean??
Old Aug 3, 2009 | 10:42 PM
1988_chris's Avatar
1988_chris
Navigator
"Rich exhaust present"
Old Aug 3, 2009 | 11:02 PM
CalvinMD's Avatar
CalvinMD
My 87 has a intermittent check engine at cruise that is on for a minute at a time and comes on about 3 times an hour...I need to get a code reader but will not waste the time until I do a full tune
Old Aug 4, 2009 | 08:30 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Is there any fuel in the fuel reg vacuum line ?
If you disconnect the cold start valve electrical connections, does it get better ?
Old Aug 4, 2009 | 11:37 AM
1988_chris's Avatar
1988_chris
Navigator
I have not tried that yet. I will test that tonight. One more piece of information I fortgot to add in my original post is, the car runs fine until the water temp gets up to 130 - 150 degress.
Old Aug 5, 2009 | 08:22 PM
1988_chris's Avatar
1988_chris
Navigator
I disconnected the cold start valve connector. I measured 3.9 ohms across the valve connector. I measured the DC resistance of all the fuel injectors, they were all approximately 16.8 ohms. I took the car for a drive with the cold start valve disconnected, and as soon as the water temp got up to about 135 degrees, the engine started skipping, and service engine light came on after about 5 minutes (code 45 again). I took the car back home and put it in park. The idle would drop down to 400, 500 RPMs for a few seconds, and then go back up to 700, 800 RPMS, and then repeat. Also I disconnected the vacuum hose from the pressure regulator, and there was not any fuel in it.
Any suggestions on what to do next would be greatly appreciated.
Old Aug 5, 2009 | 09:23 PM
JXAce's Avatar
JXAce
1988_Chris,
I'm in the same boat as you:
http://forums.corvetteforum.com/c4-t...regulator.html
First thing....go to the auto parts store and get a fuel pressure gauge and hook it to the Schrader valve on the fuel rail to see if it is holding pressure when the engine is turned off. If not, pinch the fuel return line, cycle the fuel pump to create pressure and see if the pressure still goes down (like mine is doing).
Right now, on my car, everything is pointing to fuel injectors.
How old are your injectors, FPR?
Old Aug 5, 2009 | 09:45 PM
1988_chris's Avatar
1988_chris
Navigator
My injectors are the factory originals. I'll get a fuel pressure gauge tomorrow and see where I'm at. Does the fact that the motor starts skipping after it warms up give any indication of what's happening?
Thanks for the info.
Old Aug 5, 2009 | 10:24 PM
gmboileau's Avatar
gmboileau
The skip you mention can happen when the car goes into closed loop as it warms and the integrator (short term fuel trim) is trying to lean out the mixture because of a rich condition as indicated by Code 45. It reaches it's limits and then resets which can cause a stumble. You can notice this at idle as well...the engine will lope. This is often caused by faulty injectors... make sure to measure the resistance when hot.
Old Aug 7, 2009 | 11:53 AM
1988_chris's Avatar
1988_chris
Navigator
Default tested fuel pressure
I'm still struggling with this code 45 problem.
Just tested fuel pressure, results as follows
Engine off key on - Steady 39 PSI
Engine off key off - 38 PSI slowly drops to 35 PSI after 10 or 15 minutes.
Engine on Idling - 36 PSI until car warms up
Engine on Engine Warmed up - As idle drops to 400 RPM pressure rises to 41 PSI then engine goes back to normal 700 RPM, pressure then drops back to 36 PSI - Then repeats as engine goes from 700 to 400 etc.
I tested DC resistance of all of the fuel injectors while the engine was warm, here are the results. 17.3, 17.5, 17.4, 17.5, 17.4, 17.3, 17.3, 17.2.
I'm not sure what to do next. Some other posts have indicated that this may be a fuel injector problem. I'm not sure though. Any help here would be greatly appreciated.
Old Aug 9, 2009 | 09:48 AM
gmboileau's Avatar
gmboileau
email sent
Old Aug 9, 2009 | 04:28 PM
JXAce's Avatar
JXAce
Chirs,
I just fixed my problem (re-set base idle and replaced fuel pump helped the most). I would suggest re-setting the base idle on yours as well (might not fix the root issue, but may help).
From Vader's page:
http://temp.corvetteforum.net/c4/vader86/baseidle.html
Old Aug 9, 2009 | 08:55 PM
AGENT 86's Avatar
AGENT 86
http://members.shaw.ca/corvette86/Code%2045.pdf
http://members.shaw.ca/corvette86/Fu...mDiagnosis.pdf
Old Aug 9, 2009 | 09:31 PM
1988_chris's Avatar
1988_chris
Navigator
Default Thanks
Thanks for the info Agent86, JXace, gmboileau. I'll let you guys know how I make out.
Chris
Old Aug 19, 2009 | 01:24 PM
1988_chris's Avatar
1988_chris
Navigator
Default Situation Much Worse
Disconnected MAF connector last week troubleshooting. Car ran horrible. Reconnected MAF, car ran much better. Next thing I know I get an O2 sensor code, egr code, plus rich exhuast code. Completely disgusted.
My next step is to get a real shop manual for my 88 vette.
Can someone please provide a link so I can purchase the real manual? I'm currently using a Chiltons manual, which is a little disapointing.
Chris
Old Aug 19, 2009 | 03:17 PM
AGENT 86's Avatar
AGENT 86
Here is some info from my 86, should provide help until you get your own manual. http://members.shaw.ca/corvette86/
Old Sep 2, 2009 | 09:21 PM
1988_chris's Avatar
1988_chris
Navigator
Default Finally Fixed
Used Agent 86's pdf repair sheets to troubleshoot code 13, 32 and 45 over the last month or so. All of the codes would come and go. Very frustrating. The test that led me to the fault was "shorting diagnostic terminal to ground", Run engine at 1200 to 1800 RPMs and watch for service engine light soon to stay on. Then ground o2 sensor and start engine. If light is steady ECM is bad. Puchased ECM from Ecklers $180.00. Just put it in tonight and vette runs like a champ.
Thank You to everyone who helped with this frustrating problem, especially Agent 86.
Chris
Old Sep 3, 2009 | 12:00 PM
whitebrow's Avatar
whitebrow
Great to hear - I'm looking at a very similar issue on my 91. I don't see the loss of power at speed but once I've been driving for 45 minutes or so on a warm day, she really has trouble idling. Up and down, up and down. It mostly disappeared after chucking the frisbee so I didn't worry about it much. Checked the codes a few days ago and I saw 45. I already checked the injectors a few months ago (only while cold, however) and they range from about 10 to 16. Since then I've been waiting on a new set (multecs, but they're new and free) but I think this weekend I might give the ecm check a try.
Thanks for posting your solution!
To Code 45 1988 TPI Engine skips while cruising
