Battery warning light HELP PLEASE!!!!!
Old Feb 15, 2002 | 11:32 PM
No Ordinary 91's Avatar
No Ordinary 91
Cruise-In III Veteran
Default Battery warning light HELP PLEASE!!!!!
On my 91 the little red battery light will flicker from time to time, it never stays on constantly, the only times it will flicker on is if i roll up the window and after it stops hold the button still. Also happens when the heater kicks on. The voltage is fine and doesn't even dip on the guage when this happens, all the battery connections are tight, and so I am not sure what else to try.
CAN SOMEONE HELP ME!!!!! :crazy:
Old Feb 16, 2002 | 12:58 AM
KLLRVET's Avatar
KLLRVET
Default Re: Battery warning light HELP PLEASE!!!!! (No Ordinary 91)
I know this sounds unrelated, but how does you car idle? Mine used to come on (the battery light), and the idle was poor. It turned out that the throttle body was carboned up. All I had to do was spray some carb cleaner on a rag (not into the throttle body, it is not good for the O2 sensors), open the TB, and clean the carbon off of the openings. You might try it and see if it helps.
Tony
Old Feb 16, 2002 | 01:02 AM
jfb's Avatar
jfb
The battery symbol lights when the voltage regulator in the alternator detects an over voltage or under voltage condition. Since yours flickers upon the sudden application of a load, I suspect that you have momentary (too small an interval to show on your voltmeter) low voltage condition. If it does this at idle, the alternator cannot deliver its rated current at this slow a shaft speed. Rev the engine and see if the batt symbol still flickers. If it does, then I suspect that your alternator has some open diodes and cannot deliver full current any longer and you should be prepaired for an alternator failure soon.
If the voltage stays up, I wouldn't worry about the flickering, just put it out of your mind. If the batt symbol stays on, make for home with ALL electrical eqt turned off and sharpen your alternator changing skills.
Old Feb 17, 2002 | 12:27 AM
No Ordinary 91
Default Re: Battery warning light HELP PLEASE!!!!! (jfb)
Well I think that the alternator might be putting out too much then, because on the guage a full battery showing 12 volts before you start it would be about 16 when the car is running, i'll take some pics see what you guys think
Old Feb 17, 2002 | 10:05 AM
89 Bob L's Avatar
89 Bob L
It may be something as simple as a worn belt. If you are at idle and the system gets under a load, the belt slips and is not able to provide enough voltage. When you increase the idle the belt may still slip, but it is spinning the alternator enough to provide the needed voltage.
Old Feb 18, 2002 | 06:36 PM
K87ZZ4's Avatar
K87ZZ4
I had the same kind of experience with the alternator on my truck. The battery light flickered for years (the voltage was OK, so I didn't worry about it). Then, I took the alternator off after my battery died and took it into a shop to have it tested. The guy said "the light is probably flickering, right?". He concluded that it was probably some problem with the rectifier. I decided to replace the alternator to be on the safe side and just in case it had contributed to my battery dying (such as not charging it properly). The bottom line... with the new alternator, no more flickering light. I don't know if it adversely affected charging, or not. If you want to fix the flickering light problem, then I'd suggest replacing the alternator. At least it's not that difficult to do yourself.
Good luck...
Old Feb 18, 2002 | 07:48 PM
No Ordinary 91
Default Re: Battery warning light HELP PLEASE!!!!! (K87ZZ4)
well it has happened since the new alternator, maybe I will have NAPA replace it while it is still under warranty
Thanks for the help :cheers:
To Battery warning light HELP PLEASE!!!!!
