OK, i finally got this thing all wrapped up. I pulled the dist and reinstalled it the right way this time, started the car, adjusted the timing to 6 degrees BTDC, and drove the car.
MY CRUISE IS GONE! I deleted the EGR, would this have anything to do with it? I plugged a vacuum line (the one that goes to the throttle body and would have gone to EGR valve put i put a screw in it and plugged it)
Every once in a while it surges @ idle, it seems to be completely random as to when it does it..is this related to the cruise control/vacuum line?
and it seems to stumble a bit under 1200 rpm, i think this may be the TPS, i still have to readjust it. or vacuum?
Other than that, it runs like a champ! Much better than it was with all the stock stuff.
