Injectors leaking
Old Aug 6, 2009 | 07:21 AM
butchg1948's Avatar
butchg1948
Default Injectors leaking
One of my injectors started leaking at the top so I tore the upper part of the engine apart to get the fuel rail out. I ordered new o-rings and took the rail to the Chevy dealer and had them put in the o-rings and new clips on the fuel rail.. I brought it home and installed the fuel rail and now every one of the injectors are leaking, can anyone tell me why and what should I do next.. I'm used to working on older cars and fuel injection is not my expertise.. Thanks Butch
Old Aug 6, 2009 | 07:24 AM
FICINJECTORS's Avatar
FICINJECTORS
Supporting Vendor
Originally Posted by butchg1948
one of my injectors started leaking at the top so i tore the upper part of the engine apart to get the fuel rail out. I ordered new o-rings and took the rail to the chevy dealer and had them put in the o-rings and new clips on the fuel rail.. I brought it home and installed the fuel rail and now every one of the injectors are leaking, can anyone tell me why and what should i do next.. I'm used to working on older cars and fuel injection is not my expertise.. Thanks butch
were they the stock injectors?
Old Aug 6, 2009 | 08:37 AM
WW7's Avatar
WW7
Sounds like they may have used the wrong O-rings. When I bought my injectors they came with the wrong O-rings. This was before I knew about FIC..WW
Old Aug 6, 2009 | 10:55 AM
GKK's Avatar
GKK
The O-Rings have the wrong thickness. Call Jon Banner at FIC (below your post) and he'll help you get the correct size o-rings.
Old Aug 6, 2009 | 02:33 PM
butchg1948's Avatar
butchg1948
I took the fuel rail and injectors back to the chevy dealer and now they are saying all my injectors are bad leaking from the electrical plug. Funny how only one was leaking before and now all 8 are bad.. I'm getting really bummed out for sure.. Butch
Old Aug 6, 2009 | 02:39 PM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
Old Aug 6, 2009 | 03:48 PM
MK 82's Avatar
MK 82
Originally Posted by 94ZR1
Is it your intention to help or be a wise ***?
Old Aug 6, 2009 | 04:02 PM
floridamale's Avatar
floridamale
If you were able to remove the rail you should of just gone to Napa and bought new 0 rings and reinstalled it your self. If the rail is seated right I don't believe you even need the clips. I know I didn't when I instaled Bosch lll's.
Old Aug 6, 2009 | 04:13 PM
MK 82's Avatar
MK 82
The clips just keep them from falling out of the rails when you remove them. They serve no purpose when the engine is assembled.
Old Aug 6, 2009 | 09:20 PM
GKK's Avatar
GKK
If one injector was bad, all of the injectors would've had to be replaced anyways.
Contact Jon Banner at www.fuelinjectorconnection.com and get a set of the Bosch III design direct replacement injectors for only $169 and you'll be back on the road with a better running engine.
Old Aug 7, 2009 | 07:18 AM
butchg1948's Avatar
butchg1948
Thanks for the info.. I'm going to order a set today... I'm an old school guy 60 years old and have only worked on cars that had carbs on them so this is my first time with fuel injection so it is a little scary for me to work on. I have only had this vette for 2 weeks and want to get it back on the road as soon as possible. I appreciate the great help on getting fuel injectors that I can afford. Will let you know how I make out when it is running again....Butch
Old Aug 7, 2009 | 08:22 AM
floridamale
Any questions you have just ask here, lots of help. Its a straight forward job just just need to remove lots of things to get at the fule rail, you can take some photos as you go to help. Also the thing to have is the FSM it will save you lots of time and money keeping your Vett on the road
Old Aug 8, 2009 | 01:35 AM
Arkybill's Avatar
Arkybill
Yep, I can idenitfy with this. I'm 62 and just changed the injectors on my 94 LT1. I'd seen lots of good stuff about Jon at FIC. I figure it's all true. I've messed with Holley's and other carbs since about 63(1963, that is). Hadn't EVEN seen a fuel injector out of an engine before.
Got a set of injectors from Jon, started to put them in. Hey, I thought they'd go in like the ones I took out. Couldn't get the 2nd O ring to fit in the hole. Called the number on the instruction sheet, Damn, a person answered the fone, and told me what to do. It worked, you know, like he'd actually seen what I was trying to do.
Best thing you can do is call FIC and get a set on the way. When (IF) you get confused, just call the number and things will go OK.
bill
Old Aug 8, 2009 | 08:13 AM
butchg1948's Avatar
butchg1948
My injectors are on their way.. He told me to call if I had any problems. Seems like a great guy to deal with. Can't wait to get the vette back on the road. Butch
Old Aug 8, 2009 | 08:20 AM
TorchRedlt4man's Avatar
TorchRedlt4man
From: Chicago Executive Airport, formerly known as Palwaukee
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
At the risk of sounding redundant, Jon at FIC is the BEST vendor I have ever dealt with in over forty (40) years. To see a prime example of his work in action, check out my thread:
http://forums.corvetteforum.com/c4-t...long-read.html
You are definitely in good hands!
SAVE the WAVE!
Old Aug 8, 2009 | 04:47 PM
RLG's Avatar
RLG
I don't mind being redundant, Jon is the way to go .
I am 57 and experienced the same issues of transferring knowledge from the 60's and 70"s to a 1990 rolling computer.
I had no problems installing Jon's injectors. Follow his instructions and you will be fine.
Old Aug 10, 2009 | 09:51 PM
butchg1948's Avatar
butchg1948
Well guys the injectors are in and it is running.. All I can say is WOW!!!!!!!! What a difference.. It is a whole new car. Instant horse power for sure won't know about better milage because now it is too fun to put my foot in it...LOL.. I will pass the word on these injectors for sure...
Butch
To Injectors leaking
Old Aug 11, 2009 | 08:41 AM
WW7's Avatar
WW7
Glad to here your up and running, if you have any more problems post them. There is a great amount of knowledge on this site and these guys don't mine sharing it...WW
Old Aug 11, 2009 | 09:28 AM
TorchRedlt4man
Congratulations! Nice to have your new found power!
I have checked my gas mileage closely since installing my injectors. My mileage is up about 2mpg. This is with keeping my foot into the gas pedal for the most part!
Jon IS the man!
SAVE the WAVE!
Old Aug 11, 2009 | 06:56 PM
RLG's Avatar
RLG
Fantastic!!
Glad you had the same results that I had.
