Rear Control arm bushing advise needed.
Old Aug 17, 2009 | 10:15 PM
corvettedan22's Avatar
corvettedan22
These things are breaking my ***** going back in !
Old Aug 18, 2009 | 11:08 AM
LT1CORVETTE's Avatar
LT1CORVETTE
Keep at it. Getting them in and out required a little creativity and brute strength. End result is well worth it.
Old Aug 19, 2009 | 12:01 AM
RUU's Avatar
RUU
If you didn't disconnect the spring and/or put jackstands under the hubs when you took them out, putting them back is a major PIA (been there, done that). I ended up jacking the rear part of the hub so that it would tilt enough to get the upper arm back in. Don't remember what I had to do to get the lower back though. For the other side, I measured the distance between the mounting points of the spring bolt & disconnected the spring from that side. The hub is easy to move then. Good luck.
Old Aug 19, 2009 | 12:40 AM
mickyfinn's Avatar
mickyfinn
7th Gear
You can buy complete new arms and bushes on ebay for about $110
