New transmission and SMF set up problems PLEASE HELP!@!!!
Old Aug 15, 2009 | 04:09 PM
MP6's Avatar
MP6
Default New transmission and SMF set up problems PLEASE HELP!@!!!
ok here we go...
I had a new ZF 6 seed put in my 92 lt1 with a Mcleod SMF and Mcleod clutch. It is LOUD at idle and when under semi load in a higher gear. Is this just SMF chatter? also i think they forgot to reinstall the heat sheild and sound dampaning material because i can here everything from under the car and it POURS in heat like the heater is on. The center consul gets real hot and the shift rod can burn when you touch the metal shaft. The starter is making a odd sound engageing the new fly wheel. Also I get it back and the wipers are not working. What do you guys think is the deal ????
Old Aug 15, 2009 | 05:17 PM
James93LT1's Avatar
James93LT1
Veteran: National Guard
Originally Posted by MP6
ok here we go...
Did you get a steel flywheel or aluminum flywheel?
You are going to have to remove the shifter console plate and see if they reinstalled the rubber shifter boot under the console.
Old Aug 15, 2009 | 07:35 PM
MP6's Avatar
MP6
Steel flywheel
Old Aug 15, 2009 | 08:06 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
If you don't use an original style dual mass flywheel, the trans will make noise. It won't hurt anything, but it can be annoying.
Old Aug 19, 2009 | 12:54 AM
MP6's Avatar
MP6
thanks guys! you all are a great help!
To New transmission and SMF set up problems PLEASE HELP!@!!!
