Rhino Ramp ---> not low enough!!!
Old Feb 16, 2002 | 02:03 PM
FlyboyZR1's Avatar
FlyboyZR1
Default Rhino Ramp ---> not low enough!!!
Lots of people say these are low enough for the C4, but if you have a Z51 front spoiler these ramps will NOT clear it!!!!!!!!!!!!!!
Old Feb 16, 2002 | 02:16 PM
Mikez40's Avatar
Mikez40
Default Re: Rhino Ramp ---> not low enough!!! (FlyboyZR1)
I have the Rhino ramps, and it hits my front spoiler when I go up. So I bought a 2x10 and cut a 3 foot piece and put those in front of the ramps to get a better angle.
Old Feb 16, 2002 | 03:21 PM
TA's Avatar
TA
Default Re: Rhino Ramp ---> not low enough!!! (Mikez40)
WWhat he said :yesnod:
Old Feb 16, 2002 | 04:40 PM
SlowJoe's Avatar
SlowJoe
Be glad you don't have ground effects. I wind up jacking it up and slipping the ramps in.
Old Feb 16, 2002 | 04:52 PM
Shylor's Avatar
Shylor
Default Re: Rhino Ramp ---> not low enough!!! (SlowJoe)
Yes the Rhino Ramps even rub on the stock C4's. You have to use a couple 2x12's to make them work without rubbing.
Old Feb 16, 2002 | 07:26 PM
GlockLT4's Avatar
GlockLT4
Default Re: Rhino Ramp ---> not low enough!!! (Shylor)
I made my own ramps with 2x10 pieces of wood. I used 4 steps to get it up to the 8" max lift. I measured them out so that it goes up before the ramp hits the spoiler. :D
Old Feb 16, 2002 | 09:30 PM
Wadoka's Avatar
Wadoka
St. Jude Donor '03-'04
Cruise-In 1-2-3-4-5 Veteran
Default Re: Rhino Ramp ---> not low enough!!! (Glock'94)
I use an old calculus book and an old physics book right in front of the ramps.
Finally, a good use for them.
Old Feb 16, 2002 | 10:11 PM
dizwiz24's Avatar
dizwiz24
I own Rhino ramps, have a stock ride height C4 convertible, and put a wood 2x4 in front of where the ramp starts when putting my car up on it. No problems.
That extra inch from the tire going up on the 2x4 is all it takes to get the front spoiler/air dam to clear it
Old Feb 16, 2002 | 10:27 PM
Springer's LT4's Avatar
Springer's LT4
Cruise-In III Veteran
Default Re: Rhino Ramp ---> not low enough!!! (dizwiz24)
Even with my car lowered 1.5 inches in the front I can clear the ramps with a 2x4 in front of the ramps.
Old Feb 17, 2002 | 08:15 AM
Rkreigh's Avatar
Rkreigh
Default Re: Rhino Ramp ---> not low enough!!! (Springer's 95)
who sells the rhino ramps??? my lowered ZR1 seems like it would scrape a pack of cigarettes. do they still make a "jack a vette" plate for jacking up the rear end or is this only for C5s getting these C4s up in the air is a PITA. I need to get a lift but don't really want to pay the $$$
Old Feb 17, 2002 | 09:15 AM
6spd89's Avatar
6spd89
Cruise-In II Veteran
Default Re: Rhino Ramp ---> not low enough!!! (Rkreigh)
walmart has them !!!! $30
matt
Old Feb 17, 2002 | 10:06 AM
Nathan Plemons's Avatar
Nathan Plemons
I have a pair of these ramps, the car is sitting on them right now. I've just never tried to drive up on them, I was kinda afraid they would scrape. I wind up just jacking the car up and sliding the ramps underneath. I didn't really get them so I could drive on them, but rather I got them so that the whole tire could sit properly, my old ramps just didn't like 275 tires :)
Old Feb 17, 2002 | 10:51 AM
MagRed_04's Avatar
MagRed_04
Default Re: Rhino Ramp ---> not low enough!!! (Nathan Plemons)
I purchased the set from Ecklers with the extension on them... I don't have a problem except my tires are a little wide :crazy:
:cheers:
Old Feb 17, 2002 | 11:37 AM
dtorc4's Avatar
dtorc4
Default Re: Rhino Ramp ---> not low enough!!! (Matt Black)
:lol: :lol: :lol: :smash: :cheers:
Old Feb 17, 2002 | 01:10 PM
scorp508's Avatar
scorp508
Eh' who cares? :) The spoilers are made to be bent anyways.
To Rhino Ramp ---> not low enough!!!
