Aluminum Brightener?
Old Aug 9, 2009 | 11:55 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Default Aluminum Brightener?
Is there a solution or solvant that will brighten up old dull grey cast aluminum parts without damaging them? I could bead blast some old aluminum engine parts (brackets & braces), but I don't particularily want to etch them. Any suggestions for what works well?
Old Aug 9, 2009 | 12:42 PM
M. Schumacher's Avatar
M. Schumacher
NAPA sells a product which is based on phosphoric acid. I tried it on some different things, not just car parts. Didn't seem to do a whole lot.
I have used a janitorial product (floor wax stripper) to clean all different kinds of metal. This is pretty potent stuff. The fumes will choke you and you don't want to get it on your skin. Apply, work in with a brush, let soak for a while, rinse. May blacken aluminum if left on too long.
I've had good luck with a soft wire wheel on a bench grinder, followed up with brillo pads.
Old Aug 11, 2009 | 01:23 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Thanks.
Old Aug 11, 2009 | 04:38 AM
Joe C's Avatar
Joe C
over the years, i have (glass) bead blasted many aluminum components on my corvettes without any showing signs of etching. on my 85, i bead blasted the parts, followed by an aluminum cleaner (dx533) and an aluminum (chem-film) conditioner (dx501). the parts looked factory new, and the chem-film sealed the surface form the effects of oxidation. my 85's engine looked great - even after 12 years. the ppg products are available from most major automotive paint suppliers.
http://www.popularaviation.com/docs/DX533.pdf
Old Aug 11, 2009 | 04:56 AM
Weav's Vet's Avatar
Weav's Vet
I used the Aluminum Brighter NAPA sells on my suspension parts when doing a gear change. It works great. Just spay it on and rinse it off. You cannot use it on cast pieces though. The aluminum has to be pure or as mentioned it will blacken the part.
There was a thread not long ago about polishing cast parts such as the alternator.
Old Aug 11, 2009 | 05:22 AM
Sparkostatic's Avatar
Sparkostatic
I used the NAPA stuff too.Works great on the TPI runners and the plenum.But it turned the valve covers brown.Control arms are nice and clean though...
Old Aug 11, 2009 | 08:06 AM
pmihaltian's Avatar
pmihaltian
Slingshot
WOW ! Your engine looks great; WELL DONE
Thank you for the information
Old Aug 11, 2009 | 10:04 AM
cv67's Avatar
cv67
St. Jude Donor '05
Ive beadblasted to with decent results.
If you really want it the brighest it can be with 0 damage then soda blast your parts, they will look brighter than new.
Old Aug 11, 2009 | 10:38 AM
cfi's Avatar
cfi
Joe c
beautifull engine what do you use for the rubber etc. Hoses air duct belts??
Bob
Old Aug 11, 2009 | 06:34 PM
black85's Avatar
black85
I bead blasted mine, but a mechanic I know told me to use wheel cleaner on it to keep it looking brand new.
Old Aug 12, 2009 | 01:14 PM
HVAC111's Avatar
HVAC111
Did you do this with the engine in the car? Totally assembled. Or did you dismantle the parts?
[Q
UOTE=pmihaltian;1571096800]WOW ! Your engine looks great; WELL DONE
Thank you for the information[/QUOTE]
Old Aug 12, 2009 | 05:20 PM
pmihaltian's Avatar
pmihaltian
Slingshot
I guess I don't listen too well after all. I just bought some of the NAPA stuff and tried it on my cast A/C and alternator brackets and the damn stuff turned them black. Now I will have to glass bead or soda blast them to get them back to something that looks like aluminum.
Thanks for your valuable recommendation. Too back I did not listen to you
Old Aug 12, 2009 | 05:23 PM
Weav's Vet's Avatar
Weav's Vet
Don't feel bad....I learned the hard way myself. I just tried it on a small cast piece though.
Old Aug 13, 2009 | 01:18 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Can you remember the title of this cast aluminum thread?
Old Aug 13, 2009 | 03:02 AM
Weav's Vet's Avatar
Weav's Vet
This was it. http://forums.corvetteforum.com/c4-t...ternators.html
And this is the link to the process of polishing. http://www.gmtips.com/3rd-degree/dox...ff/alt/alt.htm
To Aluminum Brightener?
