coolant sensor location on a 1988
Old Aug 9, 2009 | 09:29 PM
planet's Avatar
planet
Default coolant sensor location on a 1988
Got a "low temp" indicator that is on. trying to test coolant sensor but cant locate. Some were under the pelumn. Thanks!!
Old Aug 9, 2009 | 10:03 PM
bosshog8's Avatar
bosshog8
On a 90: center of the engine, in front under all the junk. The bottom of the intake I believe. Probably the same on yours. Take off all the intake ducting and look down below the throttle body, its in there! Might even be in the block, it's pretty deep in there. I forget exactly but I know its not easy to see.
Old Aug 9, 2009 | 10:08 PM
rodj's Avatar
rodj
Front of intake directy under TB Easy enough to see.
Old Aug 10, 2009 | 09:01 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Sounds like you want the gauge sender in passenger side head, single dark green wire, spade connector.
http://members.shaw.ca/agent86/Fuel,...%20Display.gif
Old Aug 10, 2009 | 09:15 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
They missed by ...."just that much".
Old Aug 10, 2009 | 11:57 AM
planet's Avatar
planet
Found the little bugger. Thanks for the help.
To coolant sensor location on a 1988
