Compression Distance?????
Old Aug 9, 2009 | 09:40 PM
87stocker's Avatar
87stocker
Default Compression Distance?????
I am wondering what compression distance is. While looking at pistons on summit it says 1.540 or 1.560 for compression distance. Does anyone have specs on the factory pistons on a 87. I have 56cc combustion chambers, so i want do get the optimum or most compression out of it to run on pump gas and be streetable. What is everyones opinion on this.
Old Aug 9, 2009 | 10:12 PM
rodj's Avatar
rodj
Distance from center of pin to top of piston.
When you change the rod length ; the CH has to be changed to keep the top of piston in same place.
Stock CH with stock 5.7" rod is 1.56 ish
