Seat Removal 1988
Old Aug 10, 2009 | 05:01 PM
dsmithh's Avatar
dsmithh
Default Seat Removal 1988
I need to remove both seats in my '88 so that I can: 1> replace a tunnel trim piece on the passenger side; and 2> troubleshoot an overdrive switch button issue on the drivers side. I see that there is some kind of handle in the center middle of the underside of the seat cushion, but have not been able to figure out how to remove it yet. Any suggestions?
Old Aug 10, 2009 | 05:08 PM
IRAraid's Avatar
IRAraid
Default Remove seat cushion
That wire handle is the release for the seat cushion. Press the front of the wire downward then rear ward to release. It helps to press down on the seat cushion in the middle near the front while releasing the handle. The handle pivots on about a 3" radius.
Hope this helps.
Old Aug 10, 2009 | 07:30 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Why don't you just remove the 4 nuts that hold the track to floor and pull the seat out ??
Old Aug 12, 2009 | 12:57 PM
dsmithh's Avatar
dsmithh
Hope this helps.
Thanks for the information, this worked perfectly.
To Seat Removal 1988
