headlights look like a ducks butt
Old Aug 10, 2009 | 11:44 PM
JackandCoke's Avatar
JackandCoke
7th Gear
Default headlights look like a ducks butt
sticking up outta the water. Took a little road trip and discovered the headlights wouldn't open all the way. I tried to raise them manually but didnt happen. they make the first flip then that's it. From my search I am saying the bushings are gone. Does this sound correct?
Old Aug 11, 2009 | 04:22 AM
nitronick's Avatar
nitronick
Active Streak: 90 Days
Probably.
Look at the sticky at the top of the page for instructions on how to fix.
Old Aug 11, 2009 | 10:27 AM
383vett's Avatar
383vett
Did they both go out at the same time and get stuck at the same angle? If so, maybe electrical.
Old Aug 11, 2009 | 01:45 PM
JackandCoke
7th Gear
They start to flip but just make the first turn then nada. If it was electrical I would have thought they could have been cranked up manually. The fact that they dont raise when I crank them has led me down the bushing path.
Old Aug 12, 2009 | 12:03 AM
383vett's Avatar
383vett
Are they both stopping at exactly the same instant. Maybe power going to both motors is interrupted due to a bad wire when the housings reach a certain position.
Old Aug 12, 2009 | 12:11 AM
Z51JEFF's Avatar
Z51JEFF
Its the bushings,they are shot.
Old Aug 12, 2009 | 02:13 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Never seen a ducks butt that was square and shined light?!?!?!
To headlights look like a ducks butt
