Injector Lifespan?????
Old Feb 17, 2002 | 01:21 AM
KNCRSR5R's Avatar
KNCRSR5R
Default Injector Lifespan?????
MY 91 has 111,000 miles.........just pulled the rail........have NO IDEA if the injectors are stock or not........have most of the repair records since it was a one owner car.......cant see that they have been replaced. How long is their life span?? If they are the originals......should I replace them?? Car ran great and was mechanically sound...other than the intake leak which I am fixing now. I have NO IDEA how to test these things to tell if they are OK...
All info is greatly appreciated!!!!
:cheers: :cheers:
Old Feb 17, 2002 | 01:54 AM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: Injector Lifespan????? (KNCRSR5R)
I don't know about the lifespan, but it's probably pretty long. A friend of mine has 110k miles on his LT1 and I know his injectors are stock. Car runs strong too, it dyno'd 260 hp with no signs of any fuel or ignition problems.
Old Feb 17, 2002 | 02:58 AM
vader86's Avatar
vader86
Default Re: Injector Lifespan????? (Nathan Plemons)
if youre not having any problems, then you dont need to mess with them
Old Feb 17, 2002 | 08:07 AM
Rkreigh's Avatar
Rkreigh
Default Re: Injector Lifespan????? (vader86)
If you have that many miles, it would be wise to have them flowed and checked. cleaning/flow balancing them is a worthwhile investment.
RC and SGS do this pretty reasonable. getting the injectors off isn't too bad. :yesnod:
Old Feb 17, 2002 | 08:43 AM
wheelsup's Avatar
wheelsup
My 1991 had 2 leaky injectors after only 29k miles.Sound advise from RKreigh.After 110k mile your injectors don't owe you anything. :lol: Now that you have access to them,service or replace...IMO.
Phil C
Old Feb 17, 2002 | 08:54 AM
Gregory VanLare's Avatar
Gregory VanLare
Send them to Cruizinperformance.com they will do all that is needed for $10 each. Great deal and they are great to deal with.
Old Feb 17, 2002 | 10:19 AM
KNCRSR5R's Avatar
KNCRSR5R
Default Re: Injector Lifespan????? (Gregory VanLare)
Thanks for the info guys!! :cheers:
Old Feb 17, 2002 | 02:30 PM
trrgod's Avatar
trrgod
Since you already have access to them now is the time to get new ones. Mine went at 110k. You'll feel silly doing it all over again in a few miles. A set of new ones from cruisinperformance is about $240. Why take a chance with that many miles?
Old Feb 17, 2002 | 07:15 PM
KNCRSR5R's Avatar
KNCRSR5R
Default Re: Injector Lifespan????? (trrgod)
I know its a gamble........but also......their is a VERY WIDE RANGE of prices on these things........so far I have from $240 all the way to about $900.
I feel sceptical of the cheap ones and feel like I am being ripped a new bung hole with the expensive ones!
Some say they last a very long time and others say replace them.......I am on a limited budget right now......I think I am going to keep mine, as they are good right now.....if they go in 200 miles.......all I really have is the $17.95 for gaskets and then a decision on which injector!
not being sacreligious...but I'll take my chances and hope the car gods like me for a little while longer!!!!
:D :lol:
Old Feb 18, 2002 | 12:10 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
KNC,
Hey I just replaced mine and it did make a difference. Mine only had 38k on them! I went with SVO #24 from Summit for 219.00 They are much quiter and now my car is starts easier, having a tough time keeping it running with this new setup though. At least it is running on the rich side now instead of being lean. I need to spend some serious time tuning the beast. Good luck.
Old Feb 18, 2002 | 01:21 PM
GlockLT4's Avatar
GlockLT4
These injectors seem to last a LONG time...
Old Feb 18, 2002 | 08:28 PM
corvette1990's Avatar
corvette1990
My first original set lasted 109K miles, The replacement set at the engine rebuild (new Bosch/ford #24's) half were broke outta the box. The Accels I put in have been in 9K miles with no problenm
Old Feb 19, 2002 | 08:50 AM
merrick's Avatar
merrick
My 86 TPI Trans Am has 225,000 on the original injectors(resealed once). Still runs strong.
To Injector Lifespan?????
