China wall leak?
Old Aug 13, 2009 | 06:25 AM
MR NICE's Avatar
MR NICE
Default China wall leak?
I have an oil leak from back of the intake,it leaks pretty bad at idle,question ,would the china wall leak bad at idle? or is it more likely to be the sending unit?Its pretty tight in the back I could not see very well.
Old Aug 13, 2009 | 07:35 AM
JackDidley's Avatar
JackDidley
Sending unit/pressure switch. They are under pressure. Not hard to fix.
Old Aug 13, 2009 | 08:16 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Old Aug 13, 2009 | 08:30 AM
floridamale's Avatar
floridamale
It's easier to try that then pull the intake. They also have the dye kits and a blacklight to help spot leaks. Clean it down best you can and start checking
Old Aug 13, 2009 | 01:18 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default vette
When my intake gasket cut loose it was dripping on the cat on the passenger side. People would roll up there windows at stop lights to keep the smoke out.
Good Luck Mr. Nice
Corvette Mike
Old Aug 13, 2009 | 06:57 PM
MR NICE's Avatar
MR NICE
Bummer,upon futher inspection i'm getting a bubble of water? coming from the rear driver side of intake right in the corner,so much for "The Right Stuff": I'M going to try 1 more time(LT1 intake swap) then it will be Carb swap time.FN BULL****E getting tired of messing with it.
Old Aug 13, 2009 | 07:51 PM
Aardwolf's Avatar
Aardwolf
The corners there on mine have the intake gasket notch meet the head and you've got to be careful with sealant. You can remove the dizzy and clean the area well then goop the heck out of it. I've fixed leaks that way and it does work. Force a good amount in the gap and get some inside the dizzy hole too if you can.
Edit I read your post, it's water? That would be a poorly sealing intake gasket I think.
Old Aug 13, 2009 | 07:59 PM
MR NICE's Avatar
MR NICE
I retighten the intake bolts,that fixed or slowed the oil leak but it still has a small bubble of water? in the rear corner of the intake,I have lost 0 antifreeze?Someone talk me out of going carbI'm just about at my limit
Old Aug 13, 2009 | 08:24 PM
bomar76's Avatar
bomar76
What exactly would going 50 years back in time to a carb have to do with your intake gasket problem?
No matter what kind of intake you cobble on to it, it still has to be properly prepped, proper materials used, proper installation practices used, or it's still gonna leak.
I have had ONE china wall leak in years of building up SBC's, and it was my fault all the way.
Old Aug 13, 2009 | 08:38 PM
floridamale
Just re-do the intake, the biggest thing is to drop it straight down and not move it on the install. How long ago did you switch out the L98 for the LT1?,
Old Aug 13, 2009 | 08:41 PM
MR NICE's Avatar
MR NICE
Spotless clean, felpro gaskets, The right stuff in the corners, anything i'm missing?not the first time trying to make it work,I've never had a problem installing an intake before this 1.
Old Aug 13, 2009 | 08:48 PM
bomar76's Avatar
bomar76
Toss the china wall gaskets and use The Right Stuff on the walls.
Don't just use it in the corners.
Those neoprene seals are notorious leakers.
Torque the manifold bolts in the order in the FSM.
I use acetone to clean every surface spotlessly clean.
I use just a smidgen of RTV sealant around the coolant holes in heads, no where else.
Old Aug 13, 2009 | 08:57 PM
MR NICE's Avatar
MR NICE
[QUOTE=bomar76;1571130331]Toss the china wall gaskets and use The Right Stuff on the walls.
I use just a smidgen of RTV sealant around the coolant holes in heads, no where else.[/QUOTE I use right stuff on china wall and 4 corners only
Old Aug 13, 2009 | 09:46 PM
floridamale
I just fixed a intake leak on my 87 all I used is a thin film of RTV on the intake and Right Stuff on the China Walls make sure you run the Right Stuff up and over the intake gasket where it meets the China Wall. The most important thing is not to move it after you set it on the block, and you have to work quickly before it starts to set.
Old Aug 13, 2009 | 11:09 PM
bomar76's Avatar
bomar76
My one leaker was with Blue ATV.
To China wall leak?
