Hard to start C4
Old Aug 13, 2009 | 06:47 PM
rsovine's Avatar
rsovine
Default Hard to start C4
My 84 is really hard to fire up after setting overnight. I have to crank it for about one minute or longer to get it firing. I have tried pumping the gas pedal and everything I can think of.
Someone said it could be the fuel regulator. I don't know much about the crossfire injection setup.
Any ideas if it is the fuel pump, regulator or just my stupidity?:withstupid
Old Aug 13, 2009 | 08:16 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Pumping the gas pedal doesn't do anything on an injected car. Remove the air cleaner and watch the injectors while someone cranks the engine. Do you see fuel spraying?
Old Aug 15, 2009 | 10:48 PM
rsovine's Avatar
rsovine
No gas for about 20 seconds.
Old Aug 16, 2009 | 08:55 PM
rsovine's Avatar
rsovine
The car is hard to shut off too.
Anyone have any idea?
Old Aug 17, 2009 | 06:00 PM
rsovine's Avatar
rsovine
Could it be the fuel regulator? Wow, these 84 fuel injectors are primative but sensitive.
Old Aug 17, 2009 | 08:18 PM
0Paul Ruggeri
Former Vendor
Do you hear the fuel pump coming on? If not, are you getting power back to the pump?
Old Oct 6, 2009 | 11:32 AM
rsovine's Avatar
rsovine
I am still having trouble with starting. No fuel from the injectors when cranking. I pour a little bit of gasoline down the hatch and it fires right up. When it fires up the injectors start spraying. I took it to a mechanic and he said it was the ignition module but I find that hard to believe. Would the IM regulate the injectors? I wouldn't think so.
It doesn't make sense of pouring gasoline down the throttle body and then the injectors start spraying.
Old Oct 6, 2009 | 12:17 PM
desertmike1's Avatar
desertmike1
This sounds like a fuel related problem, I don't know jack s**t about a Cross fire motor, but I would be looking real close at the fuel injection, "cold" start function of the fuel injection system. Does this engine have a seperate cold start injector?
Just accouple things to think about.
Old Oct 6, 2009 | 12:54 PM
pcolt94's Avatar
pcolt94
I don’t know much about the specifics of that engine system but here are some general suggestions.
Is fuel pump running at key turn. Check fuel pump relay. Check fuel pressure at key turn.
Fuel filter, Fuel pump
Cold start injector if it has one. (As said)
Bad injectors, leaking. (probably not)
Does not sound like the IM is bad…obviously. (IM drives the coil, not injectors).
By measuring the fuel pressure will give some real data as to what is going on.
Old Oct 8, 2009 | 12:28 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
the fuel pulsator is leaking excessively
Old Oct 8, 2009 | 09:36 AM
rsovine's Avatar
rsovine
I replaced the fuel relay and it seems to spray now when cranking.
Old Oct 8, 2009 | 10:19 AM
desertmike1
sweet
To Hard to start C4
