the pulsator is part of the pump assembly, it looks from this pictures like the hose included is to elminate/bypass the pulsator...which isn't necessarily a bad thing just wondering...
Are you talking about the item in between the pump and the metal line? If so, I agree it replaces it. I thought you were talking about the one up front.
That is the 'pulsator' which looks like in the kit is replaced by a short piece of fuel line...hopefully that clears this up thanks for the pic!
Having taken it off and see that it just slips on, I think it is a good thing to remove. That way fuel only goes to the regulator and not leak out of that thing and lower pressure.
ok, I have 94 that needs a new fuel pump and I looked at the racetronix pump, it is listed for $99.00 but when I went to pay for it the total came to $190.00?? im confused. anyone know why? http://www.racetronix.com/RX-C44-FPKG-2.html
