Problem with a 92
Old Aug 15, 2009 | 01:39 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Default Problem with a 92
The driver side bank of injectors are not firing. Does anyone know where the relays are????
Old Aug 15, 2009 | 02:01 PM
jimg's'93's Avatar
jimg's'93
Check your fuses on the right-hand side of the dash. Open the passenger door and you'll see the cover there. Now look for fuses INJ 1 and INJ 2, 10amp each.
Old Aug 15, 2009 | 02:11 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
There is not a relay, the FI's are fired by the ECM.
jaa1992's Avatar
jaa1992
St. Jude Donor '12
Swapped the fuses still same problem. Driver side injectors not firing. Verified with a noid light.
Passenger bank is fine.
Swapped in a known good ECM as well.
Trying to troubleshoot the no injector pulse on driver side
Old Aug 15, 2009 | 04:00 PM
jaa1992's Avatar
jaa1992
St. Jude Donor '12
Well add me to the dummy list. I didn't swap the correct fuses.
The 20a inj1 fuse was blown. All fixed now!
Old Aug 15, 2009 | 05:16 PM
jimg's'93's Avatar
jimg's'93
My FSM calls for 10amp fuses for both injector banks and I just verified that on the car. You might want to have another look at that fuse block and see what it calls for.
Old Aug 15, 2009 | 05:40 PM
aminnich's Avatar
aminnich
We did. His FSM said 10A for the right bank, but oddly a 20A for the left bank.
Old Aug 15, 2009 | 05:43 PM
jimg's'93's Avatar
jimg's'93
Vewwy Vewwy Stwange.
To Problem with a 92
