Please help
Old Aug 15, 2009 | 03:58 PM
rte203's Avatar
rte203
Default Please help
My car 85 C4 pulls to the left when I brake, I have replace both calipers and the Master twice! I blew out the steel lines, and replaced the rubber lines between the steel line and the caliper, Im so ill with this car! Please give me advise....
Old Aug 15, 2009 | 08:21 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Is there any thing worn or loose in the suspension or steering.
Old Aug 15, 2009 | 08:31 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
hows the rotor also check tire psi, are the pads the same on both wheels?
Old Aug 15, 2009 | 09:50 PM
rte203's Avatar
rte203
Replaced the entire Front Suspemsion, Ball joints tie rods, ect
Old Aug 15, 2009 | 09:51 PM
rte203's Avatar
rte203
New tires, I rotated front to back, New pads and rotors
Old Aug 15, 2009 | 10:01 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Do not discard the rear brakes. Inspect them and get back with us.
Old Aug 15, 2009 | 10:12 PM
rte203's Avatar
rte203
PLRX, I bled them and checked them today, I have not replaced the Calipers, altho they seem to cause no prblems When Driving the Car, If I stab the brakes only the front left will lock up, If i gravity feed the lines the left Front has the greatest amount of free flow, But it is closet to the master cylinder, It almost flow constant, whereas the right caliper drips Fast, Both of the rears drip slowly.
Old Aug 21, 2009 | 02:16 PM
rte203's Avatar
rte203
Well I was hopeing for more input, I would assume no one has had this problem, I dont think it is the rear brakes. The steering wheel as well as the nose of the car pulls to the left on hard braking..., I have replaced the entire brake system, and front end componets...... I got a 1985 lemon, Who Knew....
Old Aug 21, 2009 | 07:07 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Don't give up yet.
I had a Mustang that did this, it wasn't until I replaced and greased the slide pins that the calipers would work correctly.
Also check for caliper spread, even rebuilt calipers could have it!
Old Aug 21, 2009 | 08:01 PM
djirok's Avatar
djirok
check your cars toe camber and caster also, have it balanced out!
Old Aug 23, 2009 | 02:00 PM
rte203's Avatar
rte203
Originally Posted by jaa1992
Don't give up yet.
Im ready to try anything, should i pull the caliper pins and re-grease them? they are new as well
Old Aug 23, 2009 | 02:01 PM
rte203's Avatar
rte203
I dont understand, the aligment shop said it aligned perfect. I had replaced all of the front end parts.
rte203's Avatar
rte203
Don't give up yet.
what is caliper spread?
Old Aug 23, 2009 | 08:32 PM
ant-knee470's Avatar
ant-knee470
I am not to sure on a vette, as I am a new vette owner, But is it possible it could be the portioning valve? Just trying to help..
Ant...
Old Aug 23, 2009 | 08:50 PM
quickcat's Avatar
quickcat
Perhaps some air in your ABS? As I recall this unit is difficult to bleed but there should be a procedure in the service manual for it. You may also want to try some panic stops on a loose surface.
BE CAREFUL! This whould be to exercise the ABS unit and maybe move any trapped air out. So you will have to bleed the calipers again.
It could be a dangerous thing to do, think twice about where you do it.
Matt
Old Aug 23, 2009 | 09:25 PM
Grizzly10's Avatar
Grizzly10
1st Gear
Replace brake hose
Old Aug 23, 2009 | 10:22 PM
Calderone's Avatar
Calderone
Yes,might be your brake hoses,and yes go for the panic stop tests as well.-
To Please help
Old Aug 24, 2009 | 05:55 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Matt
No ABS on an '85. I agree with checking the hoses on the right front. Sometimes these hoses deteriorate from the inside.
Old Aug 24, 2009 | 06:52 AM
rte203's Avatar
rte203
Thanks for the advice on the brake hoses and ABS,
The 1985 Does not have ABS, So that's out.... and I replaced both the steel hose to the rubber hose, and the small rubber hose from the steel to the calipers as well. I thought it was the rubber hoses as well. both good idea but that did not solve, thank you again. At leeast you guys tried.
Old Aug 24, 2009 | 06:55 AM
rte203's Avatar
rte203
Ant...
Thanks Ant, The valve is a part of the master cyl, but works front to rear. i have also replace the master cly , twice with no change... I m so done with this car.... I dont even know what else to look for I replace the entire front of the car.... ( seems like)
