help
Old Aug 16, 2009 | 04:11 AM
91c4707's Avatar
91c4707
7th Gear
Default help
just picked up this 91 vette. i got it from a friend that says that every now and then the car will shut off and he would have to wait about 15mins to start it back up. anyone heard of this problem please let me know
Old Aug 16, 2009 | 06:05 AM
vette079's Avatar
vette079
Check codes first by grounding the top two terminals on the right (A+B) at the ALDL.
Check the injectors both cold and warm engine with a digital volt meter.
Watch the vid´s in FIC´s sticky´s on this site, you´ll get the idea how to check them.
Old Aug 20, 2009 | 12:52 AM
91c4707's Avatar
91c4707
7th Gear
thanks for the help ill see what happens also since you mentioned injectors are thier any that you can recomend
Old Aug 20, 2009 | 12:02 PM
vette079's Avatar
vette079
FIC, the one in the videos, fuel injector connection dot com...
But check them first, and call Jon at 770.888.1662 in case you´re not sure.
Old Aug 20, 2009 | 12:07 PM
cv67's Avatar
cv67
St. Jude Donor '05
Check your fuel pressure at the rail and test your coil, also.
Old Aug 20, 2009 | 06:15 PM
WW7's Avatar
WW7
If all the above fails check the Control Module, they can do what you are experiencing...WW
Old Aug 30, 2009 | 07:56 PM
91c4707's Avatar
91c4707
7th Gear
check the code nothing came up. havent checked the fuel pressure at the rail. plus the car wont pass smog due to high knox i was told that the egr needs to be replaced. can that also be the problem, my vette is 6 speed and and keeps a steady idle around 1800 and doesnt come down after running the motor.
Old Aug 31, 2009 | 10:51 AM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
Check the timing. Remember to undo the brown wire by the brake master cylinder when you set the timing.
To help
