vacuum lines
Old Aug 17, 2009 | 03:00 PM
ndanl's Avatar
ndanl
Default vacuum lines
hello,
I have 2 vacuum lines and a sensor, can anybody tell me where should I connect them ? on the sensor only two line come in ? is it important ?
thanks...
Old Aug 17, 2009 | 03:14 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
That is the EGR solenoid, it doesn't matter which goes where on the solenoid, as long as both are hooked up.
Old Aug 17, 2009 | 03:37 PM
ndanl's Avatar
ndanl
ok thanks, and where should I put the egr solenoid ? where is its place ? I can't leave it that way
WW7's Avatar
WW7
Here is a copy of the vacuam lines on the early C4s. the picture you have is of the EGR solenoid. As you can see from my picture the tube on the right goes to the egr and the one on the left goes to the line going to the vacuam canister.The solenoid gets attached to the rear thermostate housing bolt...WW
Old Aug 17, 2009 | 03:59 PM
floridamale's Avatar
floridamale
It always amazes me how these cars have been bastardized over the years things misplaced, left loose, connected wrong, it’s a long list
Old Aug 17, 2009 | 05:55 PM
ndanl's Avatar
ndanl
just got this car, it was not even starting, now with everything in place the engine runs well... new filters, new injectors, new gaskets, new fuel pump, new transmision, new etc and the shipping from US to Romania is damn expensive
Old Aug 17, 2009 | 07:17 PM
AGENT 86's Avatar
AGENT 86
It is mounted to thermostat housing, using the existing bolts.
Old Aug 17, 2009 | 08:10 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
There "was" an ear the picked up the inside t-housing bolt.
Thereby making the access to said switch next to impossible
without dismantling the plenum.... (exaggeration)
Also check all those brittle plastic lines and if necessary replace with rubber hose.
To vacuum lines
