Fuel pressure
Old Aug 18, 2009 | 09:38 PM
McGirk94LT1's Avatar
McGirk94LT1
Default Fuel pressure
OK finally stopped putting it off as it seems my fuel pressure is def the culprit. My fuel filter, pump, and sending unit are all new, less the 5,000 miles but car is still acting up. So bought myself a fuel pressure gauge. What sort of pressure should it be reading just sitting. How about at idle? Thanks all in advance.
Old Aug 18, 2009 | 09:51 PM
aminnich's Avatar
aminnich
About 43 with key on, engine not running.
Old Aug 19, 2009 | 04:34 PM
McGirk94LT1
Default strike 1
Ok, numbers are in for my 94. 42 psi sitting weather hot or cold, around 37-38psi while idling, and spikes from 40 to 35psi when revved. All those numbers seem pretty factory spec sadly. So what would be next on the check list? Idle is fine and going through the rpms is fine while cool. When it gets to around 150 degrees or more though it misfires under low rpm load or under heavy acceleration. Any ideas? My original guess was 02 sensors. Should they be next on my list?
Old Aug 19, 2009 | 07:29 PM
TWISTERUP's Avatar
TWISTERUP
What sort of running issues are you having?
I need to learn to read LOL....How old are the plugs/wires/opti cap/rotor sometimes they are not noticeable untill closed loop and as you said that's also when the PCM starts looking at the O2 sensors.
Old Aug 19, 2009 | 09:40 PM
McGirk94LT1
Currently have new wires, plugs, opti, and water pump with less then 20,000 and new fuel pump, filter and sending unit with less then 8,000 I'd say. Been progressively acting up starting about 10,000 miles ago. Just been kinda fiddling with options and trouble shooting since. So almost anything having to do with the engine and engine sensors short of the heads/block is pretty new other then fuel regulator(though my pressure is pretty much spot on). Only thing left i could think of is the 02s. Dunno.
Old Aug 19, 2009 | 11:45 PM
Arkybill's Avatar
Arkybill
My 94 LT1 ran ok, except when cold. Got good mpg. I put new fuel injectors in it (FIC). Fixed all problems, best $200 I've spent on service.
bill
Old Aug 20, 2009 | 09:22 AM
floridamale's Avatar
floridamale
It could be an injector that is just not firing right or hanging up a little causing your hesitation. I’m not sure short of replacing them or having them checked out at a shop how you would know. Have you tried to check the resistance hot & cold you may find one that is out of spec which would cause this. You sound like you have replaced every thing else. The other thing is although your wires have been replaced you might have a bad one have you tested them.
To Fuel pressure
