1986 Corvette Running Rough at Idle
Old Aug 20, 2009 | 03:53 PM
slt780's Avatar
slt780
Navigator
Default 1986 Corvette Running Rough at Idle
I have an 86 corvette that runs very rough at ilde. When started, it sputters to the point that it stalls. I changed the O2 sensor with no luck. There are no codes. At higher rpms it seems to run fine. Any ideas as to where I should start looking?
Old Aug 20, 2009 | 04:25 PM
george4's Avatar
george4
After checking the distributor cap, rotor, plugs and wires for any problems, try checking the resistance in your injectors.
Old Oct 2, 2014 | 11:32 AM
rjs86vette's Avatar
rjs86vette
Cruising
Default my 86 also has that rough idle.
to the point that my bud thinks I have a hot cam. I need to ck this inject resist. there's an intense unburned gas smell too!
Old Oct 3, 2014 | 02:37 AM
Cliff Harris's Avatar
Cliff Harris
Take the vacuum line off the FPR (Fuel Pressure Regulator).
Turn on the ignition but do not start the engine.
Check for fuel coming out of the FPR.
If the FPR diaphragm is ruptured fuel will get sucked into the plenum through the vacuum line and make your car run super rich.
A rough idle can be caused by a vacuum leak or an EGR valve that is stuck open.
Old Oct 3, 2014 | 06:34 AM
playsdixie's Avatar
playsdixie
i'd be checking my IAC too....
To 1986 Corvette Running Rough at Idle
