C4 computer options
Old Aug 21, 2009 | 11:43 AM
superc4's Avatar
superc4
Default C4 computer options
We live in texas with emissions inspections. If I convert to carb'd on a 1990 I'm assuming I would fail emissions?
We want a car thats not TOO computerized to make it easier to work on as a first project car. If this isn't do-able, whats the cheapest ecu upgrade, and fuel injection upgrade?
Old Aug 21, 2009 | 01:54 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
What do you want to do with it?
You can run an aftermarket ECU, but they're not cheap.
Old Aug 21, 2009 | 02:26 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Figure out what you want to do, tuning a FI car is not hard. Lot's of websites and books to teach you how.
Old Aug 21, 2009 | 02:44 PM
floridamale's Avatar
floridamale
What is it your trying to do ?
Old Aug 21, 2009 | 02:50 PM
superc4's Avatar
superc4
Sorry I was tired when I wrote the post. My first choice would be a carb conversion, but only if it will pass emissions, and my second choice is upgrade the fi setup if #1 is not possible
Old Aug 21, 2009 | 03:04 PM
hmmorillo's Avatar
hmmorillo
Fuel injection is not as complicated as you think. Plus, why would you want to go back 50 years and put a carb in? Do some reading and use this forum. Its amazing what these guys can talk you through.
Old Aug 21, 2009 | 03:27 PM
floridamale
You will not pass if you go to a cab set-up
Old Aug 21, 2009 | 03:40 PM
Pwnage1337's Avatar
Pwnage1337
You will not pass if you go to a carb set-up
Carbs aren't very good at emissions lol. They do make power easier and cheaper than FI though
Old Aug 21, 2009 | 03:47 PM
Demonic85's Avatar
Demonic85
You could pass emissions but you'd need all the emissions equipment still on the car and working in good order. Lean out the fuel/air ratio and you might just pass.
Aftermarket ECU's are a lot more user friendly than the stock one though and can be adjusted.
Old Aug 21, 2009 | 04:53 PM
floridamale
Not if they have a visual inspection in Texas
To C4 computer options
