'84 - this seat thing doesn't work - why???
Old Aug 21, 2009 | 05:23 PM
dchoran's Avatar
dchoran
From: Appleton, Wisconsin Boston originally - North End
Default '84 - this seat thing doesn't work - why???
My '84 with 48,500 miles was meticulously maintained by the previous owner. He made sure EVERYTHING worked like new. Very nice.
I've been luvin' it for the last month. Even lost interest in my '05 Harley bagger http://s62.photobucket.com/albums/h114/dchoran/
The one and ONLY thing that doesn't work on either seat is this:
The driver's seat is power everything - the passenger is manual.
Any ideas what is happening with that seat angle thing or how to fix it???
Strange that neither of these function - common problem???
THANKS in advance.
Dave H. Appleton, WI dchoran@athenet.net
Old Aug 22, 2009 | 09:47 AM
dchoran's Avatar
dchoran
Surely someone out there has had this problem and knows the fix??????????????
thx
Old Aug 22, 2009 | 10:14 AM
floridamale's Avatar
floridamale
When you release it dose the seat back move forward?
Old Aug 22, 2009 | 11:40 AM
jhammons01's Avatar
jhammons01
If the seat is moved all the way back.....the rear deck will prevent the back from reclining any further...
I hate to answer something so simplistically.....it could happen..
Old Aug 22, 2009 | 12:03 PM
floridamale
I was thinking the same so I wanted to know if it came forward
Old Aug 22, 2009 | 12:06 PM
jimg's'93's Avatar
jimg's'93
Sounds right to me. For both of them to fail seems odd. The seat could be so far back that the mechanism cannot 'disengage' to be functional.
Old Aug 23, 2009 | 12:17 PM
dchoran's Avatar
dchoran
The seats are not hitting the rear deck back - just a stop of some kind.
Yes they move forward - but the same way with or without hitting the angle tab - about 2 inches - the movement is the same as if you were going to hit the full foward tab to access behind the seat.
The seatback angle adjuster does nothing on either side as far as I can tell.
Do I really need to give it a nasty push???
Maybe some air cylinder is frozen???
THANKS.
Old Aug 23, 2009 | 01:24 PM
floridamale
It only moves about 2 inches back bring seat all the way forward on tract see how much movement you have
Old Aug 23, 2009 | 02:17 PM
imputor's Avatar
imputor
The bottom seat cushion comes off real easily in my '96. Just a metal clip to the seat bottom on front center. Once the cushion is removed the mechanism in question is fully visible.
Old Aug 23, 2009 | 06:25 PM
jeffp1167's Avatar
jeffp1167
rust
Old Aug 24, 2009 | 01:54 AM
jhammons01's Avatar
jhammons01
^^yup...
Old Aug 24, 2009 | 06:01 PM
dchoran's Avatar
dchoran
Awesome tips - how many vehicles have a single clip and walla the seat cushion is out-of-there. That is nice. Now where can I get a new seat cushion Does the back come off as easy???
Amazing.
THANKS guys for the tips on the "recliner" thing - actually I just figured out they both work. Travel is minimal. Guess I was expecting something like you'd see in newer vehicles. I gotta remember this is an '84.
All is well.
Dave H. Appleton
Old Aug 24, 2009 | 07:05 PM
floridamale
The upper cushion has 4 clips 2 on each side that a wire secures behind. Two in upper section and 2 mid section the way to remove is to compress the cushion from one side at a time till you feel them pop out. Lots of people have made a tool out of a wide screw driver with a V-notch cut in the middle to press agains the wire makes it much eaiser.
To '84 - this seat thing doesn't work - why???
