air pump
Old Aug 23, 2009 | 04:47 AM
sharp90's Avatar
sharp90
Default air pump
Anyone have pictures of what an air pump delete kit will look like in stalled?
Old Aug 23, 2009 | 05:19 AM
shbbykins's Avatar
shbbykins
Old Aug 23, 2009 | 10:07 AM
Snakecharmer383's Avatar
Snakecharmer383
Suprisingly I haven't done this yet, it is now on my short list.
Old Aug 23, 2009 | 04:50 PM
ndanl's Avatar
ndanl
what does the air pump do ? can it be removed ?
Old Aug 23, 2009 | 05:14 PM
Muffin's Avatar
Muffin
A. I. R. Air Injection. Injects air into the exhaust to reduce unburned hydrocarbons. It can be removed with no outward adverse effects. You will not realize any significant HP gain. What you will gain is a much cleaner engine compartment.You may,depending on your local Smog *****, have a problem passing a smog test.
Old Aug 23, 2009 | 05:18 PM
ndanl's Avatar
ndanl
thanks, is there a kit to remove the a.i.r. ?
Old Aug 23, 2009 | 05:36 PM
Muffin's Avatar
Muffin
I got mine from TPIS several years ago. I am sure all the major Corvette parts suppliers have them. Plan on $160.00 for very few pieces of metal.
Old Aug 23, 2009 | 09:40 PM
pologreen1's Avatar
pologreen1
I am getting one also from tpis
Old Aug 23, 2009 | 10:24 PM
Calderone's Avatar
Calderone
tpis,midamerica and breathless performance are the ones i know.-
Maybe they are the same,im not sure,i got mine used here for $90 shipped plus the pulley was the metal version,it was a very good buy.-
I have AC and AIR Delete pulleys,neither installed
Old Aug 23, 2009 | 10:48 PM
Muffin's Avatar
Muffin
All I would add to the delete option is to clean out all the excess piping. I had my manifolds off at the time,cut all the injection tubes had them welded shut then cleaned out the exhaust restrictions. You will not be happy to see how much of the piping hangs into and blocks the exhaust.
Old Aug 24, 2009 | 10:26 PM
samsonb's Avatar
samsonb
Anyone wanna get rid of their air pump for an L98? I cleaned the engine bay and got mine all wet. So, it rusted on the inside.
Old Aug 18, 2020 | 12:35 PM
BrantP's Avatar
BrantP
2nd Gear
Goodmorning...
Im trying to find a (how to) on using the smog pump as a pully. I have heard guys talking about removing the guts of the air pump. Can somebody point me in the right direction on how to do this.
Thanks.
Old Aug 18, 2020 | 07:05 PM
vyper202's Avatar
vyper202
Originally Posted by BrantP
Goodmorning...
Thanks.
I did mine when a vane inside it cracked and was rubbing inside the housing... dam awful screech... Its not hard but its not easy either. You have to take the back off the pump when you have it on the workbench, hammer, chisel, screwdriver and cuss those fiber vanes and you chip them out the slots and housing, then put it back together. This will allow you to use the pump as an idler pulley but not have the internals working. Took me about 2 hours total, with most of the time spent getting the vanes out....
To air pump
