Best brand 52mm throttle body
With all he brands out there for 52mm throttle bodies, has anyone been able to determine which is best or in the top 3? There are companies such as BBK, TPIS, Summit, Edelbrok, etc... are they any better than stock?
I'm looking to switch out my manifold with the Edelbrok 7107(#?) and put an aftermarket TB on it.
Anyone have a bad experience or good with any aftermarket TB's?
Looking for input, thanks
I can't see what would make any one better than another except paying for a name or if you're looking for nitrous passages.
I'd consider Professional Products. The have a 52mm polished or satin for ~$220.00 shipped. That's at least $100 less than the big names.
Now let's see who'll jump in with why one might be better than another?
Sometimes even free is too much $$. Be wary of products that seem very inexpensive or go ahead and buy one of the ebay sub 100 dollar optis
Remember you if you don't have the time or money to do it right...you'll probably end up finding the time and money to do it over.
For a 52 I'd probably settle for ported stocker. I've had great luck with my BBK 58, once it becomes a restriction I'll spring for a AS & M monoblade
MIke
MIke
MIke
So, as a buyer that does his homework, it would seem silly to spend over $100 for a product that performs the same. Just my opinion!
Jim
The 52 BBK I got has sealed bearings instead of bushings and is overall a much nicer piece than the stocker. It gives a much more stable idle as it's not leaking and the throttle rotates a bit more smoothly.
There is absolutly NOTHING (physically) wrong with the Professional Products TB.
What is wrong is the fact that they were made in CHINA (and copied as is everything PP mfgrs) but that is a different discussion.
I have used 2 of their LT1/4 throttle bodies. They fit perfectly and worked perfectly. Infact the throttle cam is the best one of the aftermarket TB's I've seen and used (and I've used them all BBK, Holley, AS&M, Accel). The build quality is better than some those aftermarket TB's I already named.
I looked to see if there was a way to put the PP throttle cam (off my old PP 58mm) on to my new AS&M Mono Blade after having to bend the cable anchor point on my intake manifold so it would fit the AS&M throttle cam. No idea why the stock TB and a Chineese TB fit perfectly - but a billet, top of the line, USA mfgr'd TB requires me to bend the cable anchor tab all to hell.
It is also true that Professional Products undercuts their own product quality reputation by selling the second quality ones without marking them as such.... Actually by the fact that they bother to sell them at all vice destroy them. $$$ is king I guess.
If you want a Profession Priodcuts TB just buy it from a reputable dealer and you won't have any problems with it.
Will
Will
Will
Will
What is wrong is the fact that they were made in CHINA (and copied as is everything PP mfgrs) but that is a different discussion....."
My BBK fit with zero issues and has been working for years now. However, there are numerous BBKs 58mm TBs with different throttle linkages so you actually have to get the right one not one that looks close enough. Not saying that was your issue ... I actually had a wrong one in my hands and thought it was close enough until I tried to install it.
MIke
