Muffler Eliminator's?
Old Aug 24, 2009 | 01:46 AM
curtis74's Avatar
curtis74
Default Muffler Eliminator's?
Just curious if anyone has ever ran these? If so, how loud are these?
http://www.parts123.com/parts123/yb....Z5Z5Z50000050D
Thanks!
Old Aug 24, 2009 | 02:32 AM
nitronick's Avatar
nitronick
Active Streak: 90 Days
which produce that powerful side exhaust sound of the 1960's
I'm guessing they will be pretty loud. Especially inside the car...
Old Aug 24, 2009 | 03:16 AM
curtis74's Avatar
curtis74
Yeah, that's what I was thinking too.
Old Aug 24, 2009 | 03:25 AM
Pwnage1337's Avatar
Pwnage1337
A lot of people (i think) run them, and resonance is very hard to avoid in a C4
Old Aug 24, 2009 | 05:46 AM
curtis74's Avatar
curtis74
Would it not be cheaper have a muffler shop just bend and install a pipe system similar to this? Just a thought.
Old Aug 24, 2009 | 08:57 AM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
I run them on my car currently.
Not really as loud as you would think.
The two large cats on my car keep it quite
You better off making your own though.
The mounts snapped off within a year.
The pipes lasted about 8 years before rotting.
Old Aug 24, 2009 | 08:59 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Thanks!
I have muffler eliminators on my LT4.
Not the kind you listed though, as mine still have the center resonator in place.
Mine just eliminated the actual rear mufflers.
As others have said, they can get a little loud on the inside (depending on rpm level).
But to me, they are just fine but wife thinks they are loud. On the outside they sound perfect.
C4's are known for a lot of resonance inside at times. But what might be annoying to one person, someone else might not think it's bad at all.
Old Aug 24, 2009 | 10:39 AM
rodj's Avatar
rodj
Originally Posted by RollaMo-LT4
Mine just eliminated the actual rear mufflers.As others have said, they can get a little loud on the inside (depending on rpm level). .
I ran the eliminators with the stock cat and car was suitably loud especialy on the outside; need to be friends with the neighbours.
When I put the test pipe in place of the cat ; I had to install open free flow mufflers because it was race car loud and I like LOUD
Old Aug 24, 2009 | 11:13 AM
WW7's Avatar
WW7
Rodj, Did you have the 2 precats on with the eliminaters or just the single cat only??...WW
Old Aug 24, 2009 | 11:26 AM
rickneworleansla's Avatar
rickneworleansla
If you have the eliminators by themselves its not that loud. That's what I started with. I had a muffler shop cut the mufflers and add pipes a few years back. If you start to do other modifications like remove the cats, add headers, add cam. etc.. Then it can get very very loud. I wonder if those with eliminators have the other mods or just sensitive ears.?
savewave's Avatar
savewave
CI 2-3-4-5-6-7-8-9-10-11-12
Wounded Warrior Escort '11
NCM Lifetime Member
I had them on my '94 convertible with the stock pre-cats/cats. I thought the car sounded good and was not troubled by resonance, although I've heard a lot of people with coupes and similar setups complain about resonance.
Rather than buying the pre-made muffler eliminators, I got a friend to cut off my mufflers, weld the tips on a straight pipe and then put that in place of the mufflers.
That was 10 years ago, but I think he charged me $50.
I didn't put on an x-pipe, so there was some popping with deceleration from higher rpms, but I liked the sound.
YMMV.
Old Aug 24, 2009 | 02:00 PM
psychodiagnostik's Avatar
psychodiagnostik
There are plenty of youtube videos with C4s with muffler eliminators, I didn't think they were that loud, especially if the resonator is left on.
Old Aug 24, 2009 | 09:53 PM
curtis74's Avatar
curtis74
Guy's,
Thanks for the feedback. I might try and do this with the resonator in place along with the stock cats and see how it sounds.
Old Aug 24, 2009 | 09:55 PM
QCVette's Avatar
QCVette
I have them on my 94. I like them.
They are a little loud, but depending on how much thottle, you can make them pretty quiet or very loud. I do a lot of highway driving and the sound is not objectionable. To me it just sounds like a good muscle car should.
My friend had them on a 96 LT4 and I was hooked. When I got my 94 I put them on.
Old Aug 24, 2009 | 10:29 PM
GKK's Avatar
GKK
I installed the muffler eliminators years ago, and it sounded OK for about a year but, I soon found the interior Resonance annoying especially if I had a passenger.
I replaced them with the Corsa catback.
Old Aug 25, 2009 | 12:39 AM
curtis74's Avatar
curtis74
I've also been looking at the Magnaflow cat back exhaust system. How do these sound? Right now my '95 has the stock exhaust and it is just way too quiet.
There are also these I found. They don't have conventional muffles but are chambered.
http://www.sweet-thunder.com/cat_bac..._corvette.html
Old Aug 25, 2009 | 09:28 AM
rodj's Avatar
rodj
Only the main cat
To Muffler Eliminator's?
Old Aug 26, 2009 | 01:37 AM
Farkas70proof's Avatar
Farkas70proof
I have no cats no resonator and no mufflers. Sometimes if you want to have a conversation and your accelerating it can be too loud but its not un bearable. If your off the throttle its just as quite as anything else. Alot of the times i turn the radio off and just enjoy listening to the engine. It sounds like it should.
Old Aug 26, 2009 | 01:42 AM
Snakecharmer383's Avatar
Snakecharmer383
I agree with Farkas...mine car is loud but I have no cats, no mufflers, long tubes etc...1st time I recorded the car with my new digi camera I blew the mic - go to youtube and search my name
Old Aug 26, 2009 | 04:13 PM
Firevette's Avatar
Firevette
Cruise-In X Veteran
This is the old motor. Stock heads/cam. Stock manifolds, no cats, and home made elim's. Couldnt keep the setup with the new motor, way too loud. Cool on a near stock car though.
