Wiper Blade Removal?
Old Aug 25, 2009 | 03:41 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Default Wiper Blade Removal?
Okay, here is a dumb one - How do you get the Trico wiper blades OFF of the wiper arm assembly? I know that they snap in place, but is there a release pin somewhere to get them off?
Old Aug 25, 2009 | 04:34 AM
braeburn22's Avatar
braeburn22
Default wiper blade removal
you insert a flat bladed screwdriver between the spring in the centre pivot and apply pressure to the spring to release the wiper from the pivot pin.
quite fiddly but it will release.
Old Aug 25, 2009 | 07:45 AM
Strick's Avatar
Strick
Drop by any AutoZone and they will show you.
Old Aug 25, 2009 | 08:00 AM
Muffin's Avatar
Muffin
Advance will to.
Old Aug 25, 2009 | 08:56 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Originally Posted by Muffin
Advance will to.
And they won't charge you, either.
Old Aug 25, 2009 | 11:55 AM
pmihaltian's Avatar
pmihaltian
Slingshot
FINALLY, I got it ! Placing the screw driver on the center spring did the trick. One was stuck, but a little oil on the spring and it came right off. Thanks for your help.
To Wiper Blade Removal?
