'91-'963rd. brake light problems
Old Feb 18, 2002 | 05:57 PM
MIKIE91's Avatar
MIKIE91
1st Gear
Default '91-'963rd. brake light problems
When tested I get 12v., bulb and socket are ok, it still doesn't light when the others do.
Old Feb 18, 2002 | 08:40 PM
c4cruiser's Avatar
c4cruiser
Default Re: '91-'963rd. brake light problems (MIKIE91)
The brake light switch controls the 3rd brake light. Up under the dash above the brake pedal. Look for a loose wire in the connector.
Where did you get the 12v?? at the socket? What did you ground the test lead to? I think the stop/chmstl lamps use the same ground circuit G401. You may want to look at the ground wire.
Old Feb 18, 2002 | 10:57 PM
bogus's Avatar
bogus
Default Re: '91-'963rd. brake light problems (c4cruiser)
hmmmm.... that explains why my 3rd comes on a little earlier than the main ones...
Old Feb 19, 2002 | 01:31 AM
jfb's Avatar
jfb
You have a bad ( open circuit) ground. Check with your ohmeter from a good ground to the wire on the printed circuit strip that is ground. You already found the one that has 12 v on it with the brake depressed. The other wire must go to ground or the lamps won't light.
To '91-'963rd. brake light problems
