UPDATE! I now have the bushings, thanks to DRM. Install will continue in the AM (T minus 7 hours)
One last question before the install.
I was planning on using the grade 8 bolts that i bought with a split locking washer and drop it down from the inside of the frame. Is the split washer the best choice to keep things tight?
Nice set up. You've got the washers switched around in your pictures. The flat washer should be on the side of the bolt head. The split washer goes next to the nut.
Hey Derrick, glad to see the install is underway. I knew the one needed to be revalved, but the others seemed to be in good order, but I'm no expert. Personally, and I'm sure I conveyed to you, I would have revalved them all anyway just for good measure.
I truly hope you don't feel I mis-represented them?
I knew that they were used and was not upset in the least. Don't even worry about it, it was in my best interest to revalve them anyway since they weren't brand new. Used parts are used parts. I really appreciated your fast shipping, fair price, and in general a nice guy to talk to. Thanks for your help!
So finally had two days off, today was the first and i finished the rears. Tomorrow i want to do the fronts, i don't know if ill have time tho.
ENJOY! (questions welcome)
HUGE SHOUT OUT TO RANDY AT DRM! DRM is awesome! In all seriousness tho, they run a great biz. Randy was more than helpfull answering my questions and getting me a spanner wrench within the time frame i needed. Thanks again Randy, i encourage everyone here, if you can support DRM for your corvette needs to go to them. %100 top notch guys over their on the East Coast.
Thanks,
Derrick
Drop the bolts into the proper holes through the shock mount hole on the bottom. And if you are really **** like me, tack the bolts with a quick weld.
On a side note, the locking washer should be under the nut, not under the head of the bolt.
I put the washer under the bolt head because i had no way of keeping the bolt from turning while i tightened it down. Now a little tack weld was my first choice, but i didn't have a welder handy so i made due. I realize you are right tho.
I like it. I still need to do the fronts over the next week and i need to find some of these for the sway bar relocate. Do you think that they are strong enough to hold the sway bar with the constant pressure?
DRM recommends cutting a hole in the frame and dropping the bolts in. I didn't want to do this on my car, so I modified the upper shock mounts by welding the hole closed and drilling a new hole 5/8" forward. This allowed me to use the factory nuts in the frame while still clearing the half shaft.
I still have to do this to the rear but I have the fronts done.
Hey, how did you go about doing your fronts. (I thought the fronts were going to be harder) My thought was drill two new holes and tap the frame to relocate the sway bar mount 5/8inch forward, but i hate tapping.
Pics welcome
I might be able to post some pics later, I have to do some work today. I ended up doing almost the same thing that Mo Bandy did with his car and he has some pictures on his web site.
I did not have to move the sway bar mounts I used a set of Energy Suspension poly bushings. The bushings have the center offset about 1/4" so when using the original hardware the sway bar can be move forward or backward by the 1/4". I also ground off the ends of the sway bar just enough to clean up the sharp edge and the tip that comes close to the spring.
OK after reading this again I need to say that all of the I's that I used should be We. A fellow Forum member was nice enough to help with this mod and he let me use his garage and lift for the weekend.
OK here is a picture of my setup.
Notice the sway bar is about 3/16" away from the coil spring at it's closest point.
We did not re-use the original lower mounting hardware for the shocks. We drilled out the existing holes just enough to use a better quality grade 8 bolt.
We had to open up the shock tower brackets to allow for the springs to fit. We used a large open end adjustable wrench to spread them apart.
