what headlightto use for better visibility?
Old Aug 28, 2009 | 08:49 AM
brent317's Avatar
brent317
Default what headlightto use for better visibility?
I want to change out the factory front headlights in my 95. but would like to see if any one can tell me about theirs, if they changed and what type and where to order from? Thanks brent317
Old Aug 28, 2009 | 09:23 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
You can use sylvanias
You can change to H4 bulb by buying the casing and the bulb
Or
Projector headlights for $16
http://cgi.ebay.com/ebaymotors/1984-...ht_5986wt_1165
HID
http://cgi.ebay.com/ebaymotors/1984-...ht_6675wt_1165
Old Aug 28, 2009 | 09:41 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
I have the Sylvania Silverstar's installed on my '96 and am very happy with them.
Much brighter than the stock ones were.
Old Aug 28, 2009 | 09:42 AM
Flame Red's Avatar
Flame Red
+1 on the Sylvania's. I changed them out years ago to the SilverStars and they are much better than stock.
Only thing is that they are glass and not plastic lenses like the OEM so they are heavier. If you motor bushings are marginal that may push them over the edge. Not hard or expensive to replace the bushings if they go - just time consuming.
Old Aug 28, 2009 | 09:45 AM
Muffin's Avatar
Muffin
I had very poor luck with a cheap H4 conversion. If you go this route spend the bucks for a good one.
Old Aug 28, 2009 | 10:19 AM
wro87's Avatar
wro87
We have had a set of HELLA repalcements in our 87' since new. Back then I had put 130/90watt bulbs in them and just last month finally burnt one out. Your standard bulb will be 65/55 watt so you can see how much more brighter these are. Don't go with alot of those blue hd look they will throw a different hue withthe light and give you some distortion and not as bright stay around 5000degK and it should be like noon day sun. The only thing you might you will do is have to remember to dim them sooner and you might want to put in heavy duty plugs in to take the higher temp but your charging system will handle it with no problem.
Good Luck wro87
Old Aug 28, 2009 | 10:25 AM
cfi's Avatar
cfi
I love my sylvania,s very good vis adn I'm old and can't see.
Red Coupe 90
Old Aug 28, 2009 | 10:55 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Hellas, The reflectors are perfect for low flying vehicles like Vettes.
Old Aug 28, 2009 | 01:40 PM
GKK's Avatar
GKK
Don't buy any cheap headlights on Ebay, they're very low quality and reflect the light pattern poorly.
Buy the Hella H4 headlight housings from http://www.rallylights.com/Hella_200...Headlamps.aspx and choose the 85/80 watt Osram H4 bulbs. The Headlamp kit with the 85/80 H4 bulbs will be $122.36.
Old Aug 28, 2009 | 06:36 PM
PLRX's Avatar
PLRX
2017 C4 of Year
Will the stock wiring handle 80W?
Old Aug 28, 2009 | 07:25 PM
samsonb's Avatar
samsonb
I plan on buying some Sylvanias at Wally World for $10 a piece. They are right below the Silverstars.
I know I don't like those lights that look like you have spot lights on the front of the vehicle. It doesn't look good, and blinds everyone.
Has anyone done that driving light upgrade as mentioned in the Corvette 101 project book?
Old Aug 28, 2009 | 07:34 PM
c4cruiser's Avatar
c4cruiser
Yes. I had the Hella housings and some APC Xenon H4 bulbs that were 130/100 watt and never had a problem. The Hella housing are real glass but there are no problems with the headlight motors and gears handling the extra weight The Hella units come with an H2 bulb and that is really not much different than a standard halogen light in terms of output.
THe Hella lamps have the lenses cut so that the low beams have a flat top to the light pattern. That helps to prevent glare from fog, rain or even snow. They also provide extra light to the right so that the edge of the road is illuminated better that stock lamps. High beams are much brighter with a higher wattage bulb and the lens focuses the light output to resemble a driving light. IIRC, CIBIE makes a similar lamp housing and it's a good upgrade too.
Old Aug 28, 2009 | 07:57 PM
WVZR-1's Avatar
WVZR-1
You can "improve" any lamps you use by improving the wiring and including relays in the power circuits! Will the "existing" handle the additional "draw" of the hi-powered bulbs? Not very well!!
Good reading here: http://www.danielsternlighting.com/products/csr.html
An up-graded harness/relay system will generally result in much superior performance even from the OE build bulbs!
Old Aug 28, 2009 | 08:12 PM
GKK's Avatar
GKK
Yes, the stock wiring can easily handle the extra wattage. My 91 Vette's stock headlight fuse is 15 amps so, it would take a total of 1500 watts before the fuse would blow.
Old Aug 28, 2009 | 08:31 PM
jsinga's Avatar
jsinga
Get the stuff from Daniel Stern Lighting. He has everything you need.
You will be amazed at the difference.
Go for the relay kit even if you use stock watt bulbs. The voltage drop in the factory wiring cuts a big chunk out of what any bulb puts out.
He's not kidding about the 130/100w bulbs burning up the factory wiring. Mine draw 18amps on low beam. It would just melt out your dimmer switch before blowing fuses.
Now I see stuff at night and drive around it, not just run over it. At least equal to any HID stuff.
JS
Old Aug 29, 2009 | 08:01 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Another happy customer using Hella E spec lenses and 100/80 H4's with stock wiring.
Old Aug 29, 2009 | 08:19 AM
vetteman42's Avatar
vetteman42
Not as bright as AGENT 86 (100/55), but "light years" above stock. Go here and call or email them they are very helpful and can advise on what exactly fits your use and purpose....http://www.rallylights.com/default.aspx
SAVE THE WAVE
To what headlightto use for better visibility?
Old Aug 29, 2009 | 08:39 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Same here! Stock and anything Sylvania makes cannot compare and I have tried all three. I will keep the Hellas.
Old Dec 23, 2009 | 05:24 PM
aboatguy's Avatar
aboatguy
Not unless they changed the electrical theory formulas since I graduated Basic Electricity and Electronics School in 1983. I believe 180 watts is more like it. V x I =P
If we solve the formula for 12 a volt 15 amp circuit we get 180 watts not 1500. However, a house circuit rated at 120 volts and 15 amps will safely handle your 1500 watt load.
Do the HL79567 ECE 200mm Headlamp bolt right in???
Mike
Old Dec 23, 2009 | 06:55 PM
jon0108's Avatar
jon0108
Yes, I did the driving light mod upgrade. You do notice a difference. Actually I only did one side and waited till nightfall to see the comparison. I believe you are upgrading from a 35 watt to 50 watt bulb.
As far as headlights, I ended up using Sylvania X-travision
