check engine light? how do i find the code?
Old Aug 28, 2009 | 01:29 PM
stevenbrian's Avatar
stevenbrian
Default check engine light? how do i find the code?
Isnt there a way to check codes on a 92? like a diagnostic mode? and if so, where do i find the definitions? please help. light just started coming on while driving down highway after about 20 minutes, then off again when car cools down.
Old Aug 28, 2009 | 02:40 PM
Red Dwarf's Avatar
Red Dwarf
This site will give you the info you need. It's good reading.
http://www.corvettephotographs.com/c4vettes/index.htm
Old Aug 29, 2009 | 09:21 AM
C409's Avatar
C409
Bend a paper clip into a "U" shape and insert it into the A & B terminals on the ALDL under dash near your right knee ... A & B are next to each other on top right of ALDL ... turn ignition to run and count the # of times the SES light flashes between pauses ... it will flash one , then two times thrice then will flash whatever is stored ... then the 'ol one-two again to let you know its done ... now you have the trouble codes ... you'll need an FSM to determine the diagnostic troubleshooting flow chart for your particular code(s) ... or post it here
Old Aug 29, 2009 | 07:23 PM
floridamale's Avatar
floridamale
Here try this site
http://www.corvettebuyers.com/c4vettes/codes.htm
Old Jan 9, 2010 | 06:06 PM
socalman's Avatar
socalman
St. Jude Donor '10
Originally Posted by floridamale
This website seems to contradict itself- the 92 uses A and G to get codes, and you don't have to count flashes- it appears on the speedo. They do say this later in the write up- but not after you might have grounded out the wrong 2 terminals.
Old Jan 9, 2010 | 09:08 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
The A-G grounding method is in the FSM. I found a used set of Gordons plugs and use that all the time now.
Where are you? If you are close to Stone Mtn GA you could come by and use mine.
Old Jan 9, 2010 | 09:17 PM
aboatguy's Avatar
aboatguy
This thread is pretty darn good info...
http://forums.corvetteforum.com/c4-t...n-96-cars.html
and although its F body based this is one of the best resources for the LT1
http://shbox.com/page/index.html
To check engine light? how do i find the code?
