ignition lock replacement
Old Aug 29, 2009 | 03:04 PM
superc4's Avatar
superc4
Default ignition lock replacement
On a 1990 corvette, we need to replace the cylinder lock, and we have the steering column panel, steering wheel, lock plate, all that stuff removed but we need to know a few more things.
How do you remove the turn signal arm and assembly?
How is the cylinder lock secured?
How will the new wires attach to the old?
Old Aug 29, 2009 | 04:32 PM
The Green Hornet's Avatar
The Green Hornet
From: Everyone needs something to believe in, I believe I'll have another beer. Wisconsin
Not sure about your 90, but on the 91 the turnsiginal stalk just pulls straight out, be carful as there are wires attached to it. To remove the cyl. lock (on the 91) there is a threaded locking pin securing it, once removed the lock cyl. just pulls straight out.
Old Aug 29, 2009 | 04:36 PM
The Green Hornet
The wires attached to the cyl. lock need to be routed down the steering column and connect at the base.
Old Aug 29, 2009 | 05:02 PM
superc4's Avatar
superc4
where is the screw that releases the turn signal arm?
Old Aug 30, 2009 | 06:32 PM
grandmastercorvette's Avatar
0grandmastercorvette
Former Vendor
Did you get it? If not call me tomorrow and I can easily walk you through this as long as you have the patience.
"DUB"
(704)394-5150
To ignition lock replacement
