Erratic Surgin at Idle
Old Aug 31, 2009 | 12:04 AM
lilytek's Avatar
lilytek
Navigator
Default Erratic Surgin at Idle
So my 94 vette is running a lot better now. But after warming up at times it randomly surges at idle, it will surge up to 1500 and then drop down to about 600. I am not sure what the issue is. It's random
Old Aug 31, 2009 | 03:13 AM
Weav's Vet's Avatar
Weav's Vet
surge is just about always a vacuum related. There is also a vacuum control module on the right side of the intake that can cause surging. I had one I finally chased down and it was a crack in the rubber elbow for PCV valve. Another time it was the vent hose for the opti. It had a hole rubbed in it from a pulley. You just about have to remove every hose and rubber fitting to find one sometimes.
Old Aug 31, 2009 | 06:37 AM
Richard G.'s Avatar
Richard G.
Default My surge at idle
My surge was caused by bad opti distributer. Using the paper clip method, I had no codes. You had to hold your foot on the brake or you were pushed into traffic by the 1500 RPM surge.
My mileage at the time was 72000 miles on my 94 Corvette.
This was not the only problem that I had caused by the opti.
To Erratic Surgin at Idle
