Can't read or clear SIR codes
Old 09-01-2009, 11:36 PM
jimmers
jimmers's Avatar
Default Can't read or clear SIR codes
I can't read or clear my SIR codes. When I ground out terminal "K" nothing happens. The INFL REST light does not flash.
I replaced my faulty DERM this spring, and it solved my seat belt and INFL REST light problem. Last week the INFL REST light came back on. The airbag light is still off.
Any idea why I cant read the codes? I read the codes on the CCM and ECM just to test my jumper wire and they work fine.
Old 09-02-2009, 06:09 PM
jimmers
jimmers's Avatar
Anyone?
Old 09-03-2009, 08:32 AM
pcolt94
pcolt94's Avatar
I am more familiar with the 92-94 vintage. However what I would do is find a shop with a Tech 1 or 2 and see if they can establish communications with all of the modules. Maybe they can clear it and give your some additional information as to what direction to take next.
The only other simple alternative is to try to clear the all computers by removing the battery cable. Then try to clear your SIR again. Check all DERM connectors and pin connections. Excise caution when in that area, use the FSM or at least disconnect the battery for 10 minutes before starting DERM work.
Old 09-03-2009, 07:48 PM
jimmers
jimmers's Avatar
All other modules I can check myself, just not the DERM. I unplugged the battery, checked all DERM connections and plugged the battery back in. The light came on minutes later. I'm assuming the "new" DERM is bad.
To Can't read or clear SIR codes
Quick Reply: Can't read or clear SIR codes
