help 92 cdm remove
Old Sep 2, 2009 | 01:47 PM
myspace's Avatar
myspace
8th Gear
Default help 92 cdm remove
i see it under the dash but i cant get out. i need to get the wires off to plug my after market radio in
Old Sep 2, 2009 | 02:04 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
The CDM is not under the dash on a 92, it is underneath the storage compartment behind the pass. seat.
Old Sep 2, 2009 | 02:22 PM
myspace's Avatar
myspace
8th Gear
92 coupe cdm. i found it under the dash. cannot get it out. help.
Old Sep 2, 2009 | 02:55 PM
mnypitVette's Avatar
mnypitVette
I think he is right, there isnt anything under my compartment back there either. My 96 was back there, but not my 92.
By the way, you are local to me. I am right in Deland.
Old Sep 2, 2009 | 03:03 PM
myspace's Avatar
myspace
8th Gear
92 coupe cdm remove. i need help to remove cdm under dash. can anydody help? this bose radio is a pain in the butt.
Old Sep 2, 2009 | 03:06 PM
Flame Red's Avatar
Flame Red
Oh Geez - this is my weekend project for Labor Day. Please don't tell me I will regret replacing my blown Blows. Mine is a 90 and it is under the pass hush panel according to the service manual.
Old Sep 2, 2009 | 04:32 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Funny, my friends 92 is in that compartment. His is a late 92.
Think you have to remove the dash pad, do a search. I know someone detailed how to do this, then remove the vent ducting and it is right underneath.
Sorry for the bad info.
Old Sep 2, 2009 | 06:36 PM
2012 coupe's Avatar
2012 coupe
Default Cdm
As I remember it is held on by two bolts on either side. There is a steel plate it sits on also. Once you get the two bolts off, just bend the steel plate down and the CDM will just slide off.
Old Sep 2, 2009 | 10:20 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
In 92 it's under the dash. Pull the glove box lid and the inner liner, the A/C vent, the side kick panel and the pad under the dash. The first ones help you see it but you have to remove it from underneath.
I've had mine out twice.
You'll also need these:
To help 92 cdm remove
