Idle will not come down when stopping
Old Sep 8, 2009 | 10:40 PM
scorp508's Avatar
scorp508
19 replies and not a single suggestion to check the TPS sensor? C'mon guys you're slacking!
Sometimes when a TPS dies it acts all funky at what should be idle and does not return to 0.54v. If you have a TPS test harness you can check it or you can puncture the wires with some small needles and use a multimeter. Sometimes an analog multimeter is best for the TPS so you can see the needle bounce up and down if it's busted.
Old Sep 8, 2009 | 11:56 PM
Vett-eight-nine's Avatar
Vett-eight-nine
Happened to me.
Old Sep 9, 2009 | 07:57 AM
Tripleblack90's Avatar
Tripleblack90
Resetting the base idle does include a step for checking the TPS setting...............
Old Sep 9, 2009 | 10:31 AM
scorp508's Avatar
scorp508
Does. Not. Count.
Seriously though, I'd like to know the TPS itself is healthy and not bouncing around first.
Old Sep 9, 2009 | 11:44 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
scorp is right. The TPS voltage needs to be check for closed throttle position and operation. You can insert your VOM probes into the TPS connector and make contact with the wires. With the ignition on engine need not be running, check the voltage at closed position .54 volts and then open the throttle slowly and watch the voltage climb. If the voltage jumps all over the place or does not respond linearly, the TPS sensor may be bad. Using a needle type gauge (analog) will help you view the voltage change as the throttle is moved.
Old Sep 9, 2009 | 12:18 PM
Tripleblack90
Yes scorp is right......the TPS voltage needs to be checked.....and one of the steps that is included in setting the base idle is to check the TPS voltage.......
Old Sep 9, 2009 | 12:22 PM
scorp508's Avatar
scorp508
I'd have to dig up the steps, but does it say to check it throughout the entire range and watch for jumpiness (is that a word?).
Old Sep 9, 2009 | 12:29 PM
Tripleblack90
http://temp.corvetteforum.net/c4/vader86/baseidle.html
